Toymods » Tech & Conversions » 22re engine to 18r steel box ?
GeeKay
Albury
22re engine to 18r steel box ? Sun, 13 June 2004 12:30 Go to next message
Can anybody advise whether a RA40 Celica steel g/box fits the 22re engine or if mods are needed..? Thanks, GeeKay.
Re: 22re engine to 18r steel box ? Mon, 14 June 2004 00:59 Go to previous messageGo to next message
All R series engines have the same bellhousing bolt pattern, so yes it will fit.
GeeKay
Albury
Re: 22re engine to 18r steel box ? Mon, 14 June 2004 09:45 Go to previous messageGo to next message
Thanks Norbie for the info..!
My project under consideration was a modest engine upgrade from the 18r in the Celica RA40 to the 22re...glad to hear the motors will fit.
Any other tips would be welcome !!
Thanks again. GeeKay.
Johnny
Sydney, OZ
Re: 22re engine to 18r steel box ? Mon, 14 June 2004 12:50 Go to previous messageGo to next message
If the 22R is a late model one, you'll need to drill one hole which is left blank on late model block ie '88-99 hilux, otherwise a straight fit.
GeeKay
Albury
Re: 22re engine to 18r steel box ? Tue, 15 June 2004 12:10 Go to previous messageGo to next message
Thanks Johnny for the update...I'll look out for the year model and the "blind" hole on the later 22RE block.
Since last post I read where the 18rg-e may be less of a fitting problem...decisions, decisions..! Now to compare power specs etc..
Thanks..GeeKay
15.6.04
Re: 22re engine to 18r steel box ? Tue, 15 June 2004 22:48 Go to previous messageGo to next message
18R-GEU will definitely be an easier conversion and it's much better for performance if that's what you're looking for. The only downside is they're a bit older than the 22R-E, but if you get a good one it's nothing to worry about.
GeeKay
Albury
Re: 22re engine to 18r steel box ? Fri, 18 June 2004 11:30 Go to previous messageGo to next message
Thanks for the info...I got a feeling the 18rg-e would be easier in the long run. Any suggestions to a site where I can see the technical specs and general info on that model engine..?
Regards,
GeeKay
18.6.04
Re: 22re engine to 18r steel box ? Fri, 18 June 2004 12:46 Go to previous message
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/GasolineEngines.html
Previous Topic:dellorto dhla dimensions
Next Topic:What's stronger std RB26 or S1 1JZ
Current Time: Thu Aug 13 08:33:29 UTC 2026
Total time taken to generate the page: 0.067345857620239 seconds
