Toymods » Tech & Conversions » 1JZ-GTE: F*%king Wires!!!!!
E30-323ti
1JZ-GTE: F*%king Wires!!!!! Tue, 03 September 2002 20:33 Go to next message
All right then!!
For those of you that have used a 1jz-gte from a JZZ30 soarer which has a 4 plug ECU loom,
What colour are the Neutral start wire & the Start signal wire??
These are hopefully the last 2 I have to find. The wiring diagram I have shows everything correctly but all the wire colours are wrong!!
Thanks for your help guys.
Glenn
[Updated on: Tue, 03 September 2002 20:33]
Grant
Newcastle, NSW, Australia
Re: 1JZ-GTE: F*%king Wires!!!!! Tue, 03 September 2002 21:52 Go to previous messageGo to next message
The last Soarer loom I did used the colours White/black and Black for start and neutral start.
E30-323ti
Re: 1JZ-GTE: F*%king Wires!!!!! Tue, 03 September 2002 22:08 Go to previous messageGo to next message
My Wiring Diag shows B/w for the NSW not W/b??
Do you recall where they went to? Or did you just splice into them next to the ECU?
[Updated on: Tue, 03 September 2002 22:23]
poombah
Forrestfield, WA
Re: 1JZ-GTE: F*%king Wires!!!!! Wed, 04 September 2002 00:19 Go to previous messageGo to next message
JZZ30's have a 3 plug ECU. Supras have a 4 plug ecu... according to the diagram i have.
E30-323ti
Re: 1JZ-GTE: F*%king Wires!!!!! Wed, 04 September 2002 00:27 Go to previous messageGo to next message
The ECU I have is for a JZZ30 A/T, It has 4 plugs.
I have a diag for the JZA70 it show 5 plugs!?!
Thanks to Grant I seem to be back on track.
poombah
Forrestfield, WA
Re: 1JZ-GTE: F*%king Wires!!!!! Wed, 04 September 2002 02:41 Go to previous messageGo to next message
Weird.. My ECU Has 4 Plugs, as does the diagram. Diagram for the JZZ30 has three large plugs... weird.
BlakeNZ
Re: 1JZ-GTE: F*%king Wires!!!!! Thu, 05 September 2002 07:45 Go to previous messageGo to next message
The Soarer (Auto) ECU has 4 plugs,and the pin numbers in each plugare as follows,34P,22P,16P,28P.
The JZA 70 ECU has 4 plugs and the pin numbers are different(26P,16P,12P,22P)My JZA70 Auto ECU has another separate plug,attached to short wires running into the ECU,possibly something to do with the auto trans maybe?My JZA70 manual loom has no plug to go into this 5th socket.
Pete
gold coast
Re: 1JZ-GTE: F*%king Wires!!!!! Thu, 05 September 2002 08:19 Go to previous messageGo to next message
My Ecu has 5 plugs. Manual JZA70 ECU. They are the same as VL1JZGTE's because we tested his ecu in my car. (He also had a supra engine)
deesonet
Toowoomba
Re: 1JZ-GTE: F*%king Wires!!!!! Sat, 07 September 2002 06:02 Go to previous messageGo to next message
As Pete said VL1JZ's was a five plug ECU on a manual JZA70 motor. The fifth plug is on a short lead and has three or four wires connected to it. I'd have to look at the harness because when I fitted the Microtech to it we had to splice some of the wires from the fifth plug.
JAZE
cronulla
Re: 1JZ-GTE: F*%king Wires!!!!! Sat, 07 September 2002 11:01 Go to previous messageGo to next message
anyone know where to get the JZA70 1jz wiring diagram no-one at toyota is interested in helping me,"sorry thats a full import"
(butholes)
any suggestions would be great Very Happy
poombah
Forrestfield, WA
icon10.gif  Re: 1JZ-GTE: F*%king Wires!!!!! Sun, 08 September 2002 01:49 Go to previous messageGo to next message
Ive got some in PDF format that I downloaded. Ummmm send us an email at poombah@iinet.net.au and i can zip them and email them back to you if you like Smile
- Russ
Pete
gold coast
Re: 1JZ-GTE: F*%king Wires!!!!! Sun, 08 September 2002 04:52 Go to previous messageGo to next message
My website has both JZA70 and JZZ30 diags on it.
JZA70
http://home.austarnet.com.au/petew/KINGSWOOD/Downl oads/JZA-70%201JZ-GTE%20JZA-70%20%20Supra%20Wiring %20Diag.pdf
And
JZZ30
http://home.austarnet.com.au/petew/KINGSWOOD/Downl oads/JZZ-30%201JZ-GTE%20Soarer%20Wiring%20DIag.pdf
And some other Interesting 1j stuff (exploded diags)
http://home.austarnet.com.au/petew/KINGSWOOD/Downl oads/1J%20Tech%20Stuff.zip
Grant
Re: 1JZ-GTE: F*%king Wires!!!!! Sun, 08 September 2002 11:21 Go to previous messageGo to next message
Pete,
you might just want to change the description of the JZZ30 diagram to JZA80 Chaser diagram. A few people have been downloading it to wire their Soarer and getting a tad confused.
Grant
[Updated on: Sun, 08 September 2002 11:23]
Pete
gold coast
Re: 1JZ-GTE: F*%king Wires!!!!! Mon, 09 September 2002 04:40 Go to previous messageGo to next message
You Mean JZX90, don't you??? I Will change it, soon.
Grant
Re: 1JZ-GTE: F*%king Wires!!!!! Mon, 09 September 2002 04:55 Go to previous messageGo to next message
Sorry, I mean JZX80. The diagram is for the early Chaser.
SupraPete
Re: 1JZ-GTE: F*%king Wires!!!!! Tue, 10 September 2002 02:06 Go to previous messageGo to next message
Has someone got a diagram for a 7MGTE? (imported '91 Supra)
Pete
gold coast
Re: 1JZ-GTE: F*%king Wires!!!!! Sun, 15 September 2002 12:05 Go to previous message
My Website has changed as of, NOW!! That so called Soarer diag link will no longer work.
This is corrected Url: Chaser Diag
http://home.austarnet.com.au/petew/KINGSWOOD/Downl oads/JZX-80%201JZ-GTE%20Chaser%20Wiring%20Diag.pdf
Previous Topic:URGENT HELP! stripped bolt
Next Topic:Help! 3T starter
Current Time: Thu Oct 22 23:05:32 UTC 2026
Total time taken to generate the page: 0.0058450698852539 seconds
