Toymods » Tech & Conversions » 1JZ universal lambda replacement?
HedgehogSandwich
UK
1JZ universal lambda replacement? Sun, 13 June 2004 19:38 Go to next message
Hi all..
I want to fit a new lambda oxy sensor...
Obviously i dont fancy paying out for the toyota price.. so has anyone successfully used a universal replacement , perhaps from bosch etc? If so which one exactly did you use?
Is the stock 1J lambda heated?
adi
celicamad
newcastle
Re: 1JZ universal lambda replacement? Sun, 13 June 2004 22:03 Go to previous messageGo to next message
i have a perfect stock 1j o2 sensor if you would like to buy it it has only done 22000 klms .
HedgehogSandwich
UK
Re: 1JZ universal lambda replacement? Mon, 14 June 2004 09:54 Go to previous messageGo to next message
cheers for the offer.. ideally need a new one as i want to be sure everything is working 100% fuel wise (i'm sure yours is fine, its just peace of mind Very Happy )
Manny
Re: 1JZ universal lambda replacement? Mon, 14 June 2004 11:47 Go to previous messageGo to next message
Not sure of a direct replacement but drop Neil Griffiths an e-mail and he may be able to help as he's sourced new alternatives before.
[Updated on: Tue, 06 July 2004 08:02]
HedgehogSandwich
UK
Re: 1JZ universal lambda replacement? Mon, 05 July 2004 17:03 Go to previous messageGo to next message
manny, are you sure it isnt heated? I emailed a supplier of lambdas and they reckon all 3 wire jap lambdas are heated?
adi
Manny
Re: 1JZ universal lambda replacement? Tue, 06 July 2004 05:38 Go to previous messageGo to next message
Adi
OK, to clarify what I meant to say, the VVTi is a 4 wire sensor and the non-VVTi is a 3 wire sensor.
I have read here that the 3 wire 1JZ one is not heated but I've never personally tested it or looked it up on the schematics and I assumed the extra wire on the latter 1JZ indicated it was heated.
Re: 1JZ universal lambda replacement? Tue, 06 July 2004 06:20 Go to previous messageGo to next message
3 wire 'should' all be heated.. the lack of a fourth wire is usually because the signal is earthed thru the body of the sensor.
the 4 wire ones have a seperate earth to minimise earthing problems through the exhaust/head/block/chassis/ECU.
new 4 wire, $60+$4postage.
http://www.materials.unsw.edu.au/~sford/oxygensens ors.html
Re: 1JZ universal lambda replacement? Tue, 06 July 2004 06:21 Go to previous messageGo to next message
and again, some wire colours for common sensors for different car makers
http://home.earthlink.net/~jcgebhart/o2sens.html
does this match up with the sensors you have?
HedgehogSandwich
UK
Re: 1JZ universal lambda replacement? Tue, 06 July 2004 16:45 Go to previous messageGo to next message
yep, it lists one otf the toyota ones as blue, black black.. with black as the heated wires. So in theory any universal 3 wire with a heated element should work..
HedgehogSandwich
UK
Re: 1JZ universal lambda replacement? Thu, 05 August 2004 15:47 Go to previous messageGo to next message
at long last i'm just about to buy one of these...
BUT i've emailed a place, gave them the resistance of the heater element and they reckon a 3 wire zirconia universal will work...
i just need to check.. does anyone know for certain that its a zirconia and not a titania?
This is the one they recommend..
Zirconia 'thimble' type
Element type - zirconium dioxide, thimble
Types available - one, two, three and four wire, 18mm thread
Heater resistance - (3 and 4 wire sensors only) 2 to 6.5 ohms
Output signal - oscillating 0.1 and 0.9 volts
Manny, who's Neil Griffiths? Is he on TIF or here?
adi
[Updated on: Thu, 05 August 2004 15:49]
Manny
Re: 1JZ universal lambda replacement? Fri, 06 August 2004 11:56 Go to previous messageGo to next message
Adi
Neil from the ALSC aka BlownSC on TIF
of Rush Imports fame.
http://www.rushimports.com.au/
HedgehogSandwich
UK
Re: 1JZ universal lambda replacement? Fri, 06 August 2004 16:43 Go to previous message
yep cheers manny, sent him an email and he got back to me fairly quick.
Previous Topic:MA70 problems...
Next Topic:how 20v's VVT work? want to mod into adjustable pulley
Current Time: Fri Nov 20 09:23:42 UTC 2026
Total time taken to generate the page: 0.006417989730835 seconds
