Toymods » Tech & Conversions » 4AGTE cold start
pulcino
Mackay QLD
4AGTE cold start Mon, 14 June 2004 00:33 Go to next message
Heres the thing: When I put my last turbo on I diddnt hook up the cold start water hoses cos I used there outlet to go to the turbo.This wasnt an issue till I got a shift kit in my automatic. Then cos it idled at 1200rpm in park when I put it into gear It clunked.The idle screw was out of adjustment so I pulled the throttle body off and made a new gasket that effectively blanked the air passages off so it diddnt work any more at all.
Diddnt cause a problem with cold start just have ta crack the throttle and sit with it for a few seconds.But seams to have made an unbelievable difference to driving response and performance. PLEASE EXPLAIN??????
Re: 4AGTE cold start Mon, 14 June 2004 02:41 Go to previous message
so previously you DID NOT blank off the cold idle up passages on the underside of the TB?
If you did not, then what was happening was air was constantly passing through those cold idle up passages PAST the butterfly and giving you a higher MAP reading hence you were running rich (less differential pressure across the butterfly).
When you blanked it off, the differential pressure became correct, hence the improved performance due to correct MAP readings.
You see, it works by the temp of the water - when the water got hot, those passages closed off and air flowed normally. When the water is cold those passages are open and the car runs rich. Of course when there is no water, the temp never reached the 70-80degC odd that closes those passages.
Previous Topic:What turbo flange is this?
Next Topic:AE86 Chassis Reinforcements?
Current Time: Sat Oct 31 06:44:35 UTC 2026
Total time taken to generate the page: 0.034873962402344 seconds
