Toymods » Tech & Conversions » MA61 brake problems
joorsh
MA61 brake problems Mon, 14 June 2004 04:43 Go to next message
LONG POST - here goes
I have an MA61 wih a 7m-gte convsersion. I'm getting a strange problem with my brakes now, which I believe is a vacuum hose off somewhere.
Here's basically what happens:
If I apply the brakes slowly and evenly, I get perfectly normal braking.
If I jump on the brakes REALLY quickly (in the case of emergency braking, for example), nothing happens. The brake is almost impossibly hard to press down - it's the same as when you turn the engine off and press the brake pedal a few times. It gets REALLY hard to press down, as if the power assisted braking is doing nothing at all.
I don't quite understand why though, because I can feel the power assisted braking working perfectly if I apply the brake pedal slowly. It's only if I stomp on it that it doesn't work.
I believe I have found the vacuum hose causing the problems, but I don't know where it should be going. I've attached some piks below with the hose in question. Does anyone know where this hose is supposed to go to? I can see it's coming off the brakes, but I need to know where it goes to. Ideally, if someone could also give me a vacuum hose diagram for the MA61 and the 7M-GTE that'd be great.
At the moment, the hose in question taps off the brake pressure/vacuum line and runs off along the firewall.
http://members.iinet.net.au/~josh_and_sarah/hose1.JPG
http://members.iinet.net.au/~josh_and_sarah/hose2.JPG
The little mini vacuum diagram under the bonnet isn't even remotely useful, and the Haynes workshop manual doesn't go into enough detail either.
Help please - I'm scared of driving in case I have to jump on the brakes!
-J-
Re: MA61 brake problems Mon, 14 June 2004 04:48 Go to previous messageGo to next message
joorsh wrote on Mon, 14 June 2004 12:43
Thats perfectly normal.
As for the hose, there shouldnt be anything Teeing off the brake vacuum hose.
It should go straight from the manifold to the booster.
That other little unit, the charcoal canister is supposed to be connected to one of the outlets above the throttle body, not off the brake booster line
Remove the T and see how she goes.
Oh, and bleed your brakes too.
wilbo666
Re: MA61 brake problems Mon, 14 June 2004 04:54 Go to previous messageGo to next message
If you start your car with your foot on the brake pedal does it depress? It should.
Also isn't there meant to be a one way valve going to the brake booster (can't see if yours is there..)
Re: MA61 brake problems Mon, 14 June 2004 04:57 Go to previous messageGo to next message
wilbo666 wrote on Mon, 14 June 2004 12:54
Good point Wilbo, yes, yes there should be
That could be your problem.
I'd say they removed it to put in that T piece
joorsh
Re: MA61 brake problems Mon, 14 June 2004 05:58 Go to previous messageGo to next message
I know that the brakes are supposed to be difficult to press down with the engine off - I was just giving that as an example of what my brake feels like when I stomp on it - as for the tee-piece, it is currently blocked off and goes nowhere. I have also tried removing the tee-piece and running it direct to the booster - still no luck.
And that IS the booster than it runs off to - that little vacuum line running along the back of the firewall goes from the brake manifold to the booster?
And something about a one-way valve? Does anyone have a pik of it? Or even a dodgy mspaint sketch will do!
-J-
Re: MA61 brake problems Mon, 14 June 2004 06:29 Go to previous messageGo to next message
http://oz-enet.com.au/~peewee/eng_conv_2/brake_booster_2.jpg
Little white/yellow thing at very top of pic.
In the line
wilbo666
Re: MA61 brake problems Mon, 14 June 2004 06:33 Go to previous messageGo to next message
joorsh wrote on Mon, 14 June 2004 15:58
I was curious as to if the brake pedal goes down further when you start the car with you foot on the brake pedal (this is a test to see if the brake booster is working).
One way valve..stolen from CrUZsida, site, so kudos to him.
http://oz-enet.com.au/~peewee/eng_conv/gbox_in_1.jpg
See the little white thing in series with the hose? Thats the one one valve Smile
EDIT: dammit you bitch you beat me too it! Laughing
Re: MA61 brake problems Mon, 14 June 2004 07:12 Go to previous messageGo to next message
wilbo666 wrote on Mon, 14 June 2004 14:33
'course I did
I got a better picture too!!
wilbo666
Re: MA61 brake problems Mon, 14 June 2004 07:38 Go to previous messageGo to next message
bite my hairy ass Razz
joorsh
Re: MA61 brake problems Mon, 14 June 2004 12:02 Go to previous messageGo to next message
Why does mine look totally different? I have a metal rail at the back there, whereas you all seem to have a hose. Could my rail incorperate the one way valve already?
wilbo666
Re: MA61 brake problems Mon, 14 June 2004 12:45 Go to previous messageGo to next message
Try blowing/sucking through it?
You should be able to suck air in from the end that connects to the booster but not blow.
Re: MA61 brake problems Mon, 14 June 2004 12:47 Go to previous messageGo to next message
Those guys posted photos of an MX73 Cressida, which isn't terribly helpful in this case. The line you've tee'd into looks like the cruise control actuator line, although that's just going from memory. The one-way valve is much closer to the booster on an MA61, and it looks different to that. If it wasn't cold and dark outside I'd go and have a look at mine, but instead I'll just sit here and speculate. Razz
Anyway, the symptoms you describe kinda sounds like a punctured booster diaphragm. It's worth checking out.
BlackSupra
Re: MA61 brake problems Mon, 14 June 2004 12:58 Go to previous messageGo to next message
Hving arsed around all day in that particular section of the engine bay im pretty sure i have 1 line going to my now removed cruise control servo/actuator and another to a carbon canister.
wilbo666
Re: MA61 brake problems Tue, 15 June 2004 12:30 Go to previous messageGo to next message
http://www.norbie.net/Cruise060102/medium_Image05.jpg
I think its the little metal thing behind the maser and above the brake booster (hehe cheers jemery Razz)
http://everest.fit.qut.edu.au/~n4150414/Cressida%20Pictures/dsc00215.jpg
And mine is on the firewall (ahh look at the turd)..
Re: MA61 brake problems Tue, 15 June 2004 22:46 Go to previous messageGo to next message
Stop posting pics of 5M-E's. It hurts my eyes!
ma61_turbo
Re: MA61 brake problems Wed, 16 June 2004 12:42 Go to previous messageGo to next message
Norbie wrote on Mon, 14 June 2004 22:17
Indeed it is the cruise actuator line.
I'm curious as to why there is such a mess of hoses there? It's no wonder something isn't right!
Re: MA61 brake problems Wed, 16 June 2004 13:47 Go to previous message
well the 2 big fat ones are for the remote oil kit Smile
Previous Topic:1jz intercooler swap
Next Topic:Amplifier Alternator whining
Current Time: Sun Nov 22 08:27:38 UTC 2026
Total time taken to generate the page: 0.008554220199585 seconds
