Toymods » Tech & Conversions » Beware when making your own short shifter mods
Skip
icon4.gif  Beware when making your own short shifter mods Mon, 14 June 2004 13:16 Go to next message
Decided I needed to shorten the extremely long throw on my 4WD R151 box by adding to the length of the shaft under the pivot point. I added a total of 32mm, and guess what? It works like a piece of crap. So im taking 12mm off, so the added length will be 20mm, will see how it goes. So yeah, just be careful how much you add if you do this modification.
Re: Beware when making your own short shifter mods Mon, 14 June 2004 13:29 Go to previous messageGo to next message
I added 19mm to my W box shifter, and it's pretty damned short, I don't think anyone would want to ever go any shorter! I'd suggest 10-15mm for most applications, depending on how bad the original is. Remember to replace all the plastic bushes on the gearshift at the same time Evil or Very Mad
Skip
Re: Beware when making your own short shifter mods Mon, 14 June 2004 13:37 Go to previous messageGo to next message
First gear is in the engine bay, second is in the back seat Razz
gearb0x
Re: Beware when making your own short shifter mods Tue, 15 June 2004 06:18 Go to previous messageGo to next message
yeah the landcruiser shifters have massive throw hehehe
Re: Beware when making your own short shifter mods Tue, 15 June 2004 07:35 Go to previous messageGo to next message
oh yeah dude... anywhere from 5-15mm is the MAX i would lift up the shifter...
30mm is just INSANE! Razz
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Beware when making your own short shifter mods Tue, 15 June 2004 08:14 Go to previous messageGo to next message
Meh, my new one's 28mm longer. Smile
I've tried it on the box out of the car, & it's hella short but seems workable, the moment of truth will be when I bolt a seat back in with the gearbox installed, I can't wait to see what it's like. It's also been sitting too far forward for the last year & a half, which is also being remidied, finally. It should be a bit different.
omegaman
SYDNEY
Re: Beware when making your own short shifter mods Tue, 15 June 2004 08:29 Go to previous messageGo to next message
I'm actually looking to buy a short shift kit for a celica steel case box. Can anybody help me where to get one from.
I'm in sydney so in the area would be good.
ed_ma61
Lost in the K hole
Re: Beware when making your own short shifter mods Tue, 15 June 2004 10:00 Go to previous messageGo to next message
i (& joel) made mine 16mm longer and i find it purrrrfecto
M.J.H
Re: Beware when making your own short shifter mods Tue, 15 June 2004 10:30 Go to previous messageGo to next message
omegaman wrote on Tue, 15 June 2004 18:29
I just took the top half of the gearstick off on mine.
Might not work in a sedan though.
Manny
Re: Beware when making your own short shifter mods Tue, 15 June 2004 10:34 Go to previous messageGo to next message
We just did a run of 15 shifters on the ALSC for the R154 Soarer guys, 18-20mm is what we used based on the C's/TRD short shift kits.
Works a treat... Cool
fatmr2
Re: Beware when making your own short shifter mods Tue, 15 June 2004 10:50 Go to previous messageGo to next message
I was going to make a TRD copy out of mine for my mr2 but later found i got one with the halfcut Smile
The difference is the hole is exactly 13mm higher than the original spot. Plus the 10mm spacer on the bottom.
Havent had a chance to try it out yet but i've been told there pretty good.
The one for my car sells for $395 so you can see how making your own would be the cheaper option.
Skip
Re: Beware when making your own short shifter mods Tue, 15 June 2004 23:24 Go to previous messageGo to next message
Lots of differing opinions here, but because the landy throw is so far I think 20mm might be alright. If it's not just means more cutting, welding and milling Very Happy.
omegaman
SYDNEY
Re: Beware when making your own short shifter mods Thu, 17 June 2004 10:52 Go to previous messageGo to next message
Does anyone want to make me one.I'll do an exchange with my gear stick and a cash adjustment, PLEASE.....
Skip
Re: Beware when making your own short shifter mods Thu, 17 June 2004 23:45 Go to previous messageGo to next message
Put it back in the car down to 20mm, and dammit the gearbox keeps jumping out of second Sad. I figure that:
a. Wasnt welded up straight enough
b. Either the spacer plate is too high, or the gear stick is too short
Better go pull it apart again.
YelloRolla
On your mum!
Re: Beware when making your own short shifter mods Fri, 18 June 2004 08:41 Go to previous message
Skip wrote on Mon, 14 June 2004 23:37
Landcruiser gear shift = wooden spoon in a bowl.
Previous Topic:in event of a crash...
Next Topic:Modified S/C outlet
Current Time: Fri Nov 20 18:36:19 UTC 2026
Total time taken to generate the page: 0.1629581451416 seconds
