Toymods » Tech & Conversions » 4AGTE exhaust
sebta22
4AGTE exhaust Tue, 15 June 2004 01:19 Go to next message
I am about to have my exhaust installed for my 4AGTE but I need to get peoples experience / ideas on which size exhaust to get. I have seen some setups on 1600 tubrocharged cars which have 2.5" systems and they run quite well but also some have 3" systems. Is there any benefit in having 3" as this about $180 more expensive.
Does having a 3" system seem overkill as 2 litre and 3 litre turbo systems use these?
45aken
NSW.south coast.Drifting
Re: 4AGTE exhaust Tue, 15 June 2004 01:27 Go to previous messageGo to next message
high boost - 3"
lower boost - 2.5"
the 2.75" piping cost too much as it is an uncommon size. 3" will give you more to play with an the future.
i am by no means an expert on the 4 age engine, but im running 3.5" on my rex Very Happy
my $0.02
sebta22
Re: 4AGTE exhaust Tue, 15 June 2004 04:48 Go to previous messageGo to next message
bumpy Smile
optionUP
Perth, WA
Re: 4AGTE exhaust Tue, 15 June 2004 05:40 Go to previous messageGo to next message
OK,
I have a 2.5" press bent exhaust on my turbo sprinter, which means that it narrows down to about 2" going over the diff. This restriction causes boost to come in at 4000 rpm, peak at about 6500 rpm, then die off at higher revs.
So, I'm currently saving for a 3" mandrel system, which will hopefully bring boost in earlier and hold it strong all the way to 7000-7500 rpm, and make more power, too. Sounds worth it to me!
The only challenge is to make sure it ain't loud as hell.
fatmr2
Re: 4AGTE exhaust Tue, 15 June 2004 11:28 Go to previous message
I made a 3inch one for my gte but then again im going for a fair bit of power. I hope the muffler i had made will be enough to keep the noise down Smile
Most people i've talked to who build them go for a 2.5 inch.
Previous Topic:Roll Cage: Through Dash, or Around Dash.
Next Topic:fuel
Current Time: Thu Nov 19 08:24:31 UTC 2026
Total time taken to generate the page: 0.0047779083251953 seconds
