Toymods » Tech & Conversions » quickie: 4AGE injectors
45aken
NSW.south coast.Drifting
icon2.gif  quickie: 4AGE injectors Tue, 15 June 2004 01:23 Go to next message
will 4AGZE injectors fit straight into a 86kw bigport engine? or will i need a 4AGZE fuel rail?
us using the fuel rail and injectors a better option than just injectors?
ae86trueno
Re: quickie: 4AGE injectors Tue, 15 June 2004 02:00 Go to previous messageGo to next message
4AGZE Injectors will fit the bigport fuel rail,
But the 4AGZE fuel rail wont fit if its from a small port Head, as the spacing is different.
Ben
AE86 Trueno 4AGE.
45aken
Re: quickie: 4AGE injectors Tue, 15 June 2004 02:37 Go to previous messageGo to next message
thank you.
injector chart
Nippon Denso 200 pink 2.7ohm Toyota 4AGE
Nippon Denso 210 blue 2.4ohm Toyota 4AGE
Nippon Denso 213 beige 13.8ohm Toyota 4AGE
Nippon Denso 250 green 13.8ohm Toyota 4AGE
Nippon Denso 250 violet 13.8ohm Toyota 4AGE
Nippon Denso 365 red/ orange 2.9ohm Toyota 4AGZE
i've shortened this table down a bit, now i have one other problem. the 4agze injectors 365cc have a resistance (ohm) of 2.9 compared to what i think is the bigport resistance of either 2.7 or 2.4ohm
will this be a problem if im running a microtech or other replacement ECU?
[Updated on: Tue, 15 June 2004 02:54]
Re: quickie: 4AGE injectors Tue, 15 June 2004 04:42 Go to previous messageGo to next message
no. they are still "low Z" if they were around 1ohm, maybe an issue..
whatever ECU you use will need PWM (peak and hold) or you will need resistors befoe the injectors (Ohmite do some nice heatsink 25W ones)
CYa, Stewart
10sec_rx7
Syndey
Re: quickie: 4AGE injectors Wed, 16 June 2004 00:17 Go to previous message
microtech will run any resistance injectors, dosent matter if they are 1ohm or 20ohm,
Previous Topic:microtech? thoughts
Next Topic:LOOK AT WHAT I JUST DONE IN MY 1J
Current Time: Thu Nov 19 10:24:16 UTC 2026
Total time taken to generate the page: 0.021512031555176 seconds
