Toymods » Tech & Conversions » 4A-G/GZ Pulsation Damper
dorikin ichiban
Auckland, New Zealand
4A-G/GZ Pulsation Damper Wed, 04 September 2002 04:38 Go to next message
Are they the same for the 4A-GZE and 4A-GE?
Talking about the Blue Top 4A-GE and AFM GZE
haggis
Re: 4A-G/GZ Pulsation Damper Wed, 04 September 2002 07:34 Go to previous messageGo to next message
Pulsation dampner?
I'm not sure what bit you're talking about.... Harmonic balancer mabey?
More info please.
Craig.
RA23_Sean
Western Sydney
Re: 4A-G/GZ Pulsation Damper Wed, 04 September 2002 10:38 Go to previous messageGo to next message
On the fuel rail? Fuel pulsation damper?
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: 4A-G/GZ Pulsation Damper Wed, 04 September 2002 13:38 Go to previous messageGo to next message
Freak i would say that they would be the same, just the regulator as far as i can tell is different. i havnt even got mine (pulsation damper)on, i've been wondereing if i should put it on?? the red and black top ge, doesnt even have a pulsation damper, so it might not really be needed.??
dorikin ichiban
Re: 4A-G/GZ Pulsation Damper Wed, 04 September 2002 20:08 Go to previous messageGo to next message
I thought you'd need the pulsation damper as it has that negative/ground? cable that goes from the pulsation damper to the intake manifold.
Oh, and the Pulsation Damper is the other thing that is in the Fuel Rail
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: 4A-G/GZ Pulsation Damper Wed, 04 September 2002 21:40 Go to previous messageGo to next message
Freak negative fround wire? mate you've got a wierd engine there! the only thing that has any type of wires going to it on my fuel rail, is......nothing. the only thing's that are on the fuel rail are: the regulator/the return line from it/vacum line from the vsv, the inlet line from the fuel filter (which the pulsation damper mounts on with) which does not have any wire what so ever (look at a manual), also you have the fuel line going to the cold start injector.
dorikin ichiban
Re: 4A-G/GZ Pulsation Damper Wed, 04 September 2002 21:46 Go to previous messageGo to next message
my bad Smile
http://homepages.ihug.co.nz/~stompyz/images/engineefilayout.gif
On this image they have got the PULSATION DAMPER AND PRESSURE REGULATOR incorrectly named. They are vice-versa
It does go to the cold start injector.
Must be too early in the morning Smile
Does the GZE have a cold start injector?
[Updated on: Wed, 04 September 2002 21:47]
feral4mr2
Bundaberg, Qld.
Re: 4A-G/GZ Pulsation Damper Wed, 04 September 2002 22:03 Go to previous messageGo to next message
Freak mmmmmmmmm............
i'm not sure if that diagram is wrong or maybe it's just a completely different setup to any ge i've ever seen. the fuel reg is (on mine) the one that say's (on your diagram) the pulsation damper. and the pulsation damper (on mine) is what in the diagram says is the fuel reg.???!!!??
it must be wrong, as in that diagram it's fuel reg has no return line, which i bet is on the bottom side of the (so called) pulsation damper, there is the fuel return line. as the vsv is a vacum switch, it operates the fuel reg, not the pulsation damper.(and your diagram shows a vacum line to it).
oh, yeah the ze does have a cold start injector, it is mounted on the cast pipe after the intercooler b4 it goes into the inlet manifold.
dorikin ichiban
Re: 4A-G/GZ Pulsation Damper Wed, 04 September 2002 22:53 Go to previous messageGo to next message
That pic is for a RWD 4A-GE, and I'm pretty sure that its labelled wrong for that motor anyway Smile
kingmick
Banned by his request
moved to tamworth
Re: 4A-G/GZ Pulsation Damper Thu, 05 September 2002 11:49 Go to previous messageGo to next message
the gze has a pulse dampener and a pressure reg. i would imagine the dampener is for when the throttle is snapped closed the dampener smoothes the loading on the pressure reg and the fuel pump or to stop a chance of a fuel line splitting or for economy as it would help to keep a even spray pattern, take your pick. either way you can run without it fine. ive yet to see a race car with one but then again i havent seen every race car.
mick
TE72_Turbo
Re: 4A-G/GZ Pulsation Damper Thu, 05 September 2002 12:58 Go to previous message
It is my understanding that a pulse damper on a fuel rail feed is placed there to attempt to maintain a constant pressure in the rail to ensure accurate fuel delivery. It is particularly important on an EFI system where all injectors are fired simultaneously (rather than sequentially), as the sudden surge of fuel leaving the rail will momentarily drop the rail pressure before the injectors close again. In reality this all happens so fast that you may not be able to measure a difference, but as a realtime test, squeeze the rubber fuel line just before the pulsation damper with your fingers, and see if you can feel the fuel pulsing in the hose as the injectors open and close.
What i've always wondered is why it is often recommended to upgrade fuel line diameter to increase fuel flow, when the damper itself 'looks' to be a huge restriction in its design?!?
Previous Topic:7M-GE manual for taking head and soforth off
Next Topic:4agze into ta22
Current Time: Tue Oct 27 08:06:18 UTC 2026
Total time taken to generate the page: 0.0054280757904053 seconds
