Toymods » Tech & Conversions » Thermostat?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Thermostat? Wed, 04 September 2002 05:08 Go to next message
Hey guys,
My friend was driving his Magna down to Canberra. Anyway, I look across at his dash (since he's pretty new to driving) and I notice the temperature gauge sitting below cold.
I told him to pull over. Popped the bonnet and the radiator was freezing cold.
Anyway, sitting there for a while, the temp gauge started to creep up.
We started driving again and the temp gauge dropped down again.
Been driving around the last few days and the car takes a long time for the needle to go up, and doesn't go up that much.
I'm suspecting that the thermostat is stuck wide open. Would this be right?
Grega
melbourne.victoria.austra...
Re: Thermostat? Wed, 04 September 2002 05:13 Go to previous messageGo to next message
i'd suggest you're pretty much well on the money same problem early VN's have dude.
GIN51E
Berowra-Sydney
Re: Thermostat? Wed, 04 September 2002 08:33 Go to previous messageGo to next message
pull her apart and have a look, unless someone put the wrong type of thermostat in it.
Nark
Cabramatta, NSW
icon4.gif  Re: Thermostat? Wed, 04 September 2002 23:53 Go to previous messageGo to next message
Is it unhealthy for the car to be running this way?
I'm thinking that it prolly is, especially on the freeway...
GIN51E
Berowra-Sydney
Re: Thermostat? Thu, 05 September 2002 00:09 Go to previous messageGo to next message
the way an engine is built is that it has all these little gaps and tolerences and so forth so when the engine is all warm and at operating temperaturte everything then has the right amount of gap and so forth, so for an engine to run best and have less wear it wants to be running at operating temperature and plus by the sounds of it the engine is running very cold and therefore the oil isn't even getting to operation temp.
i'd say you want to fix the problem or at least fill it with a very low number oil.
gt20v
Re: Thermostat? Thu, 05 September 2002 14:24 Go to previous message
probably not healthy for your wallet, as the ECU runs open-looped together with rich mixture, trying to warm up the engine to 80-82 degrees, but never reaches 80 degrees.. Smile waste petrol..
Previous Topic:4AC and 4AFC
Next Topic:7M-GE manual for taking head and soforth off
Current Time: Mon Oct 26 14:20:38 UTC 2026
Total time taken to generate the page: 0.056288003921509 seconds
