Toymods » Tech & Conversions » Supra MA70 powersteering
drummerboy
Supra MA70 powersteering Tue, 15 June 2004 18:55 Go to next message
Hey Guys,
I started my Supra ma70 up after letting it sit idle for 3 weeks. The power steering pump was whining badly and the steering was laboured and shuddery. I had a spare pump from an import engine, and with a bit of parts juggling between pumps I fitted the other pump. On start up the same whine is heard and the steering has not changed at all. What do you reckon it might be...a blockage in the steering rack, maybe? Thanks in advance dudes.
Re: Supra MA70 powersteering Tue, 15 June 2004 22:42 Go to previous messageGo to next message
Check for air leaks in the system, and yes blockages anywhere in the system can also cause those symptoms. I had a similar thing happen recently when one of the hoses got a pinhole leak and started drawing air in; you'll know this is happening if you see little bubbles rising up in the fluid reservoir when the engine is running.
drummerboy
Re: Supra MA70 powersteering Wed, 16 June 2004 04:29 Go to previous messageGo to next message
Thanks Norbie,
that sounds like it could be the problem. Cheers.
drummerboy
Re: Supra MA70 powersteering Wed, 16 June 2004 11:00 Go to previous messageGo to next message
I'm getting bubbles in the reseviour so like you said Norbie, its an air leak. I tried pump-bottle spraying some water on the hoses and connections to hopefully hear when the hole blocked with water, but had no luck. Is there any other way to locate the air leak, or should I take it to some front end people? Thanks.
Stenno
Re: Supra MA70 powersteering Wed, 16 June 2004 22:26 Go to previous message
When you changed the lines, did you bleed the system? This can take up to 15 minutes or longer to do properly.
If it's on the high pressure side it will leak fluid and will be obvious. Recheck all the hose clamps and if any look sus, replace them.
Previous Topic:ke20; auto tunnel bigger than manual?
Next Topic:3tgteu cam saddle torque
Current Time: Wed Oct 28 13:09:27 UTC 2026
Total time taken to generate the page: 0.079146146774292 seconds
