Toymods » Tech & Conversions » in event of a crash...
STR8 2.8
in event of a crash... Wed, 16 June 2004 06:06 Go to next message
microtech d4s fuel computer...
simple question:
how does it turn the fuel pump off in event of a crash.
is it run off ign on?
Chris
[Updated on: Wed, 16 June 2004 06:09]
Re: in event of a crash... Wed, 16 June 2004 06:11 Go to previous messageGo to next message
no idea, but i highly recommend the fuel pump relays from volvos. they detect if there are ignition pulses and trun off if there are none.
also some cars have crash switches, which permanently switch off the pump in the event of a high speed collision..
better to have a physical backup in case ECU's fry....
Re: in event of a crash... Wed, 16 June 2004 06:19 Go to previous messageGo to next message
I've seen people trigger the fuel pump off the oil pressure sensor... as soon as the engine stops the fuel pump stops!
STR8 2.8
Re: in event of a crash... Wed, 16 June 2004 06:22 Go to previous messageGo to next message
here's the situation:
teh microtech wiring diagram has one side of the fuel pump relay going from pos batt to computer, the other side goes pos batt to fuel pump.
i want to wire the fuel pump lead onto the fuel pump wire from the circuit opening relay.
is that a bad idea..
i dont wannna have the pump running whenever the car is in on/ign.
so basically i want to know if the microtech will cut power to the relay if it does not sense map or ign or something.
[Updated on: Wed, 16 June 2004 06:23]
rustfree
Re: in event of a crash... Wed, 16 June 2004 06:32 Go to previous messageGo to next message
good to hear people discussing this. heard a story from a mate about a dude who had and under bonnet fire in his piaza powred gemini. fuel pump kept pumping high pressure hard core as he jumped from his rolling car. not much he could do. i think he could salvage the wheels.
[Updated on: Wed, 16 June 2004 06:33]
Sigmeister
Adelaide, SA
Re: in event of a crash... Wed, 16 June 2004 07:03 Go to previous messageGo to next message
What about just an in-cabin swith. Connected to the negative of the fuel pump. So it will always run as normal until the switch is flicked turning it off instantly. Perhaps a missle style switch, but turn it around so it is always on until you flick it? Yes, this will need to be activated manually, so if you are un-conscious it wont really help.
STR8 2.8
Re: in event of a crash... Wed, 16 June 2004 07:10 Go to previous messageGo to next message
but im thinking this must be unnecessary,
surely microtech thought of this?
STR8 2.8
Re: in event of a crash... Wed, 16 June 2004 07:16 Go to previous messageGo to next message
rang microtech:
apparently it just stops when the engine does.
they werent exactly sure on how Rolling Eyes
but it does.
so i assume that it would have to be either:
the coil stops & it shuts off the fuel pump circuit
or
the map sensor sensing no pressure, shutting the circuit off.
4a-c
Sutherland Shire
Re: in event of a crash... Wed, 16 June 2004 07:23 Go to previous messageGo to next message
Does your car work yet?
Re: in event of a crash... Wed, 16 June 2004 09:38 Go to previous messageGo to next message
It's even easier, if your ECU can't manage it: go to a place that does LPG conversions, and buy a lock off controller. It's a little box that connects the IGN, GND, Coil - and the fuel pump relay, and when the engine stops, it has to less than 3 seconds later. You could even grab one from a wrecker Evil or Very Mad (They're about $20 new)
STR8 2.8
Re: in event of a crash... Wed, 16 June 2004 10:23 Go to previous messageGo to next message
4a-c wrote on Wed, 16 June 2004 17:23
haha not yet.
it runs, but its not what id call driveable.
mrshin: that sounds like a good idea, even if the microtech "can" do it. just that piece of mind i suppose.
Re: in event of a crash... Wed, 16 June 2004 11:19 Go to previous messageGo to next message
mrshin wrote on Wed, 16 June 2004 19:38
Mr Shin, thats exactly what the Volvo circuit does..
good to hear they are available new.. it is ALWAYS good to have a backup or even 2... oil pump switches are ok, but some can fail on.. you need a system that is gauranteed to dail off..
in the US i have heard they have "rollover/crash" switches.. usually in the boot, so if car stops suddenly, or is not the right way up, every shuts off..
microtech should do it, but you'd hope they knew why Wink
Megasquirt cuts off fuel if it doesn't get an ignition signal for 2 seconds.
Re: in event of a crash... Wed, 16 June 2004 13:46 Go to previous messageGo to next message
I know that with the microtech in my car, the fuel pump runs for 3-4 secs while key is on "on" position, then stops of the car isn't running. Dont know how unfortunately Smile
Sigmeister
Adelaide, SA
Re: in event of a crash... Wed, 16 June 2004 22:48 Go to previous messageGo to next message
draven wrote on Wed, 16 June 2004 23:16
All EFI cars do this regardless of what ECU they are running. I think it is to prime the lines.
Ben Wilson
Re: in event of a crash... Wed, 16 June 2004 23:46 Go to previous messageGo to next message
I know my Haltech will only trigger the fuel pump after it detects an ignition pulse (and for a few seconds to prime the lines after you turn the key).
STR8 2.8
Re: in event of a crash... Thu, 17 June 2004 07:00 Go to previous messageGo to next message
found out..
mines like draven's, i guess all microtechs are the same.
the pump runs for about 4-5 secs then turns itself off.
kingmick
Banned by his request
moved to tamworth
Re: in event of a crash... Thu, 17 June 2004 10:47 Go to previous messageGo to next message
run it off a oil pressure switch! it is very very very important you guys all do this as if your knocked out or trapped in the car you are history. i have seen very expensive race cars go up in flames and the drive get badly burnt because it wasnt wired to a pump cut-off(imagine 2 bosch 600hp pumps at 65psi pumping avgas out!). if you get a pressure switch that switches at say 15psi it will save your life and also have the added bonus of saving you bottom end if the pressure drops as it cuts the fuel pumps, you will still have to change the bearings unless your really lucky or its low revs but bearings are alot cheaper than a rebuild.
mick
Johnny
Sydney, OZ
Re: in event of a crash... Thu, 17 June 2004 12:25 Go to previous messageGo to next message
the D4s uses the ignition pulses ie see the flashing LED at the bottom.
xpimp
melbourne
Re: in event of a crash... Thu, 17 June 2004 12:30 Go to previous messageGo to next message
Sigmeister wrote on Thu, 17 June 2004 08:48
This is not true for all cars Sad
Re: in event of a crash... Thu, 17 June 2004 14:53 Go to previous messageGo to next message
Plus many cars use rollover/hard impact switches on either the fuel pump, or the whole electrical system, that cut the power if something gets hit hard, or lands lid down Evil or Very Mad
hemi twofifteen turbo
Re: in event of a crash... Thu, 17 June 2004 15:09 Go to previous messageGo to next message
Oil pressure switch is a good idea, the only problem with it is that it is switches negatively. In the very unlikely but still possible situation that the wire is squashed in between a panel, or somehow touches any metal part of the car the circuit can remain on.
Most EFI computers use the crank angle sensor, or ignition pulse
depending on what type it is. The wolf 3d computers when first
switched on (ignition) prime the fuel system by turning on the pump relay from anywhere from 1 to 255 seconds (adjustable) then
turns off. If any input trigger signal is detected, the pump is immedetly turned on again, and will remain on while input trigger pulses are detected.
Also holden style delco (1227808) also works on the same principal, and i would almost be my life that the microtech does the same as well.
As mentioned the LPG solonoid cutoff switches are the easiest to add in if your not running a computer and want a good auto cutout feature. Good for carby elec fuel pumps that would noramlly be pumping against a closed needle/seat vavle, getting
hot and heating up fuel.)
Man there are a lot of fuel blowing up stories out there Wink
YelloRolla
On your mum!
Re: in event of a crash... Fri, 18 June 2004 08:37 Go to previous messageGo to next message
Microtech do switch off by way of sensing whether or not the engine is running (ign input I believe) if there is no igntion signal, then it stops the fuel pump in a couple of seconds.
Try it with the engine running, stall the engine (easy if is manual) and you will see that the pump is disarmed in about 2 secs, this is the same as Wolf and the same as Nissan.
Factory Toyotas use (older ones anyway) a flip/flop relay that uses 1st signal from the crank wire and the 2nd from the airflow meter.
Oil pressure switch will be of little value when you are trying to start your car - at least until oil pressure is sufficient.
Fattony
Re: in event of a crash... Fri, 18 June 2004 09:05 Go to previous message
Well i know that my pumps use a signal from the ignition coil, no spark no pumps. Dont know if this would be relevent in the event of a accident, but i dont plan to have one anyway so there would be no need to worry bout that
Previous Topic:What's stronger std RB26 or S1 1JZ
Next Topic:Beware when making your own short shifter mods
Current Time: Fri Nov 20 18:44:10 UTC 2026
Total time taken to generate the page: 0.0070230960845947 seconds
