Toymods » Tech & Conversions » Diff removal??
Diff removal?? Wed, 04 September 2002 09:17 Go to next message
Ok I will be removing the diff in the TA22 on friday so i'm just wondering if anyone has any tips or tricks? What steps should I take to remove all the links?
BigBadBenny
Brisbane, Queensland
Re: Diff removal?? Wed, 04 September 2002 09:40 Go to previous messageGo to next message
Ok stand back ppl.....professional TA22 diff remover coming through Laughing
bloody hell the number of these frigin diff's I've pulled out.
anyway,
need.
*one hose clamp
*17mm spanner i think
*12mm spanner for the shockies
*10mm spanner i think
*trolly jack makes things easy
jack the car up, take the rear wheels off, crawl undernigh and undo the handbrake cables, put ya hose clamp on and then undo the brake fluid line. undo both shockies on the diff end(much easyier), then put your trolley juck under the center of the diff and take a little bit of weight off, undo the panard rod, and then undow the lower and upper control arms, let the trolly jack down pull the diff out from undernight the car and point and yell at it "BAD DIFF!!!!"
sit down and have a beer to get ready to put the new one in.
I think thats all
Re: Diff removal?? Wed, 04 September 2002 09:52 Go to previous messageGo to next message
A long bit of 2" water pipe is always good to put over the end of a breaker bar for additional leverage.
Celica_RA40
Re: Diff removal?? Wed, 04 September 2002 11:01 Go to previous messageGo to next message
Dont forget to put jack stand under the car before you crawl under it otherwise your a bloody idiot.
Re: Diff removal?? Wed, 04 September 2002 12:14 Go to previous messageGo to next message
Yep already got the car stands under the car Very Happy
Hey Benny, Whats the hose clamp for? Just to stop the fluid comming out?
[Updated on: Wed, 04 September 2002 12:15]
BigBadBenny
Re: Diff removal?? Wed, 04 September 2002 21:15 Go to previous messageGo to next message
yeah if I recall righly there is a "T" type join on the diff to allow fluid to go to each side, simply put the clamp on the rubber hose going down to it. oh also I forgot, get a hammer, it feels good to hit things when they don't dso what they are supposed to do Laughing
Re: Diff removal?? Thu, 05 September 2002 02:22 Go to previous messageGo to next message
Thanks.. I'll keep the hammer in mind too Cool
Re: Diff removal?? Thu, 05 September 2002 08:33 Go to previous messageGo to next message
Alright I give up Evil or Very Mad How the f#*$ do you remove that shitty little hose that goes from the car body down to the T piece on the diff?
Alainve
Newcastle NSW
Re: Diff removal?? Thu, 05 September 2002 10:52 Go to previous messageGo to next message
if you cant undo the 10mm fitting on the hose cos its rounding (happens to old lines) use some vise grips to clamp it good and tight and there shouldn't be a problem. Very Happy other than replacing the fitting.
Re: Diff removal?? Thu, 05 September 2002 11:05 Go to previous messageGo to next message
Thats not the problem! I have the fitting loose but the hose turns with the fitting! And the hose will only turn a few times and thats it! So its not enough to get the fitting out! Is the nut/fitting meant to be loose on the hose so it can undo with the hose turning? If this is the case I might just cut the hose and replace it when the new diff goes in!
Also I'm glad that somebody told me about useing some spring compressers Very Happy
Re: Diff removal?? Fri, 06 September 2002 06:09 Go to previous messageGo to next message
Any Help?
BigBadBenny
Re: Diff removal?? Fri, 06 September 2002 07:53 Go to previous messageGo to next message
sorry forgot about the springs Rolling Eyes
mine just pull out cause they are lowered,
don't worry about spring compressers, just when you put the new diff in leave the panard rod off, put the wheels back on and then lower the car back down, slip the bolt back in for the panard rod and she's bickies.
ok, to save cutting the hose undo it at the top end above where your hose clamp is, then when that end is off, unscrew the other end and then screw the loose pipe back onto the main line to save you loosing brake fluid
Re: Diff removal?? Fri, 06 September 2002 08:16 Go to previous messageGo to next message
Well the only problem now is I've rounded the nut on the brake line Crying or Very Sad
Hunty
Re: Diff removal?? Fri, 06 September 2002 10:13 Go to previous messageGo to next message
try filling a couple of sides flat....very very carefully! then get a good quality shifter in there lock it up tight and hope for the best!
Re: Diff removal?? Fri, 06 September 2002 10:20 Go to previous messageGo to next message
I think I might just try a really good pair of vice grips! Failing that I may just get the mobile brake man to do the job cause i'm just a lazy prick that does'nt like hard work Rolling Eyes
BigBadBenny
Re: Diff removal?? Fri, 06 September 2002 21:50 Go to previous messageGo to next message
few ways to get around the rounded nut.
Use a pair of vice-grips,
get a file and file the nut back into shape,
use a pipe spanner Surprised
or call the mobile guy
Re: Diff removal?? Fri, 06 September 2002 22:48 Go to previous messageGo to next message
Well I think the pipe wrench will be a bit of a tiht fit so I'll pass on that!
The file trick sounds like to much hard work, so that just leaves the vice grips and failing that I'll call the mobile guy!
Either way I'll get the f#*$er off Very Happy
Re: Diff removal?? Wed, 11 September 2002 10:08 Go to previous messageGo to next message
Well the whole diff removal process has been put on hold for a while! Somehow I contracted the Chicken pops Crying or Very Sad and have been stuck in bed for weekend and most of this week and most likly some of next Confused
If anyone over the age of 18 hasn't had them I recommend going to the doctors and getting vaccinated! The older you are when you get them the worse they can be! The doctor said my case was one of the worst he had seen! He was worried about it getting into my brain Rolling Eyes and causing a blood clot and killing me! I was like fark......I thought it was just like a rash that got itchy! My spots did'nt get itchy at all just bloody painful and I was also very dizy, and you can forget about sleeping comfortly when you have big puss filled blisters on ya head!
Oh, and ya can forget about getting ya knob sucked when you got them down there too Rolling Eyes Crying or Very Sad
[Updated on: Wed, 11 September 2002 10:10]
Re: Diff removal?? Wed, 11 September 2002 13:31 Go to previous messageGo to next message
I've had them twice already (too bad, you are only supposed to get them once Sad ), so heres hoping I dont get them again!
BigBadBenny
Re: Diff removal?? Wed, 11 September 2002 21:30 Go to previous messageGo to next message
Horay for me never had them,
Never ever had a known diesease.
Touch wood, touch wood, touch wood, touch wood, touch wood, touch wood,
Very Happy
Re: Diff removal?? Thu, 12 September 2002 02:38 Go to previous message
You can get them twice if you did'nt get a good dose the first time! But if your over 18 and you hav'nt had them I really reccomend getting vaccinated! Trust me, you dont want them like I have them Crying or Very Sad
Previous Topic:Covers over RA23 brakes
Next Topic:How much for a local 100kw 4AGE??
Current Time: Sat Oct 24 19:44:04 UTC 2026
Total time taken to generate the page: 0.0056240558624268 seconds
