Toymods » Tech & Conversions » 1UZ Crown wiring questions
1UZ Crown wiring questions Thu, 17 June 2004 11:24 Go to next message
I know someone who is fitting a 1UZ from a Crown somethingoruther into a Cressida.
What I want to know is will the ECU bitch about stupis things that are missing? ABS, Traction control?
Also whats the go with the fan in this crown? Hydraulic? Confused
Any help thanks?
Re: 1UZ Crown wiring questions Thu, 17 June 2004 14:50 Go to previous messageGo to next message
Hmmm, Crown's I've seen have all had a normal clutch fan
celica_freak
newcastle
Re: 1UZ Crown wiring questions Thu, 17 June 2004 16:15 Go to previous messageGo to next message
hi
it sounds a alot like a 2jzgte jap half cut aristo [gs300]
I've been told that if u run a after market ecu that u must also use the original ecu so that the auto box runs sweet as well .
this involves wireing up resistrs and caps to trick the original ecu into thinking that the motor is fine therefore keeping the box in run mode not limp mode[get me home safe]
this idont hnow for sure but will soon find out when i get to thatbit
Re: 1UZ Crown wiring questions Thu, 17 June 2004 21:14 Go to previous messageGo to next message
The plan is to use the standard ECU, but i'm just worried about the ABS and traction control.
Grega
melbourne.victoria.austra...
Re: 1UZ Crown wiring questions Thu, 17 June 2004 21:24 Go to previous messageGo to next message
speak with sideshow....when he wired up his hilux he found a few issues but, nothing that couldn't be overcome (re: the abs and traction control module)
and yeah my fan on the front of my 1UZ is the hydraulic variety - no thermo fan that i'm aware of.
Re: 1UZ Crown wiring questions Thu, 17 June 2004 21:49 Go to previous messageGo to next message
Sweet ok.
So how does the fan run? I mean is there a pump on the engine or something else? Can the pump be removed? I think a conventional thermo fan will be used the Cressida, too much hassle to use the hydro fan me thinks.
sideshow
Re: 1UZ Crown wiring questions Thu, 17 June 2004 22:16 Go to previous messageGo to next message
hey cool1
its not a prob if if u dont run the abs /traction ecus
if u run the auto u will need to wire up the abs ecu or u can get a signal divider
im doin tests on mine at the moment
but the crown ecus are a bitch to wire up perfect
i am doin tests on mine and soon i can sell u the dividers at the correct settings
if they work on my hilux
i can give some info out but not alot
as im sick of givin shit out and makin no money for it
sorry but this is mu everyday business and if i give too much out it will hurt me in the future
but my 1uz crown v8 with 2 ecus runs perfect now
i do also have the abs ecu fitted but soon i hope to get rid of it and replace it with an electronic device once i do more tests
for me to wire up a crown with both ecus would usually cost over 1000 bucks once u buy the signal dividers and other parts
so as u can see its not a job u can do in a day
[Updated on: Thu, 17 June 2004 22:18]
Darren
Re: 1UZ Crown wiring questions Thu, 17 June 2004 22:34 Go to previous messageGo to next message
I drove Sideshow's ute on the weekend and can vouch for the signal divider, it does a great job of cleaning up the auto's shift pattern.
I'll be buying one when he gets them sorted out, my auto is driving me nuts.
Darren.
Re: 1UZ Crown wiring questions Thu, 17 June 2004 22:40 Go to previous messageGo to next message
You will have no issues at all if you choose to go manual. Hook up about 4 wires and you're off.
If you choose to run the auto, the only issues will be the speed sensor signals.
Cambelt and I played with his intact halfcut. The purple and white wire provides the engine and auto ECUs with a 1 pulse per tailshaft revolution signal. We think the black and orange wire going to the auto ECU carries a 4 pulse per revolution signal but will confirm this if someone can supply us with a CRO.
You only need one of these signals for the auto to shift properly, but of course the engine light will come on and when you do diagnostics, it will spit out some codes for the speed sensor (I think they are codes in the 60s?).
There is a long thread I started about a month or 2 ago about this. Grant (Sixworks) provided extremely useful information and I posted a series of pics showing how to modify the auto to produce the one pulse per revolution signal. For you Sydneysiders and further north, Sideshow sells the 4 pulse per revolution signal generators that plug into the speedo drive for about $150. Here in Melbourne, Ringwood Speedos sell them for about $120-130.
Grega
the fan is the same as the ones on most RWD mounted engines (like 4AGE) it just bolts to the pulley on the waterpump. there is nothing fancy about it just has a hydraulic clutch in it (same as the v8 fans on the old commodores) which basically spins it slower/faster depending on RPM - no wires, pumps or pipes going to it.
[Updated on: Thu, 17 June 2004 22:41]
Re: 1UZ Crown wiring questions Thu, 17 June 2004 22:50 Go to previous messageGo to next message
Grega, you mean viscous coupling. 'Hydraulic' sends the fear of God into some people - they think of the 1JZ Soarer engines and their hydraulic pump arrangement.
The hydraulic fan could be useful in some tight fitting applications.
[Updated on: Thu, 17 June 2004 22:51]
Re: 1UZ Crown wiring questions Thu, 17 June 2004 22:56 Go to previous messageGo to next message
Cool1 wrote on Thu, 17 June 2004 19:24
Shane, what model Cressida?
If its an MX83, then just source the ABS gear from the 91-92 Grandes (I think thats all that came with ABS), and then you'll have ABS and Traction Control for the UZ too.
May well be worth a look.
Re: 1UZ Crown wiring questions Thu, 17 June 2004 23:23 Go to previous messageGo to next message
Thanks for the informaton. I'm sure once the wiring gets started there will be more questions.
Grega, The fan I am talking about is not what you are talking about. This fan is mounted on the radiator and has to hoses going to it.
Grega
Re: 1UZ Crown wiring questions Thu, 17 June 2004 23:28 Go to previous messageGo to next message
thats what i'm on about dave
heres my motor
http://www.vncommodore.com/images/lexv8/DSC00217.JPG
seee da fan
[Updated on: Thu, 17 June 2004 23:28]
EvilJack
Sutho/Hills NSW
Re: 1UZ Crown wiring questions Fri, 18 June 2004 00:21 Go to previous messageGo to next message
if anyone has gone to start their car and found that the motor is missing i guess you would have to question grega where he was the nite before Razz
Grega
Re: 1UZ Crown wiring questions Fri, 18 June 2004 00:33 Go to previous messageGo to next message
same goes for the 2 7M's in teh background Very Happy
EvilJack
Sutho/Hills NSW
Re: 1UZ Crown wiring questions Fri, 18 June 2004 01:24 Go to previous messageGo to next message
thats what i was refering to...the numerous amount of engines Razz
Re: 1UZ Crown wiring questions Fri, 18 June 2004 02:20 Go to previous messageGo to next message
Grega the engine in question doesn't have that type of fan. Also something small but maybe significant, the engine in question has a Toyota badge on the top of it whereas your has a V8 badge.
Grega
Re: 1UZ Crown wiring questions Fri, 18 June 2004 06:16 Go to previous messageGo to next message
shane its prolly a late crown motor then, mines an early type.
more fanny photos
http://www.vncommodore.com/grega/DSC00258.JPG
http://www.vncommodore.com/grega/DSC00259.JPG
[Updated on: Fri, 18 June 2004 06:22]
Re: 1UZ Crown wiring questions Fri, 18 June 2004 07:29 Go to previous messageGo to next message
I think the halfcut may be a 94 crown Rolling Eyes
sideshow
Re: 1UZ Crown wiring questions Fri, 18 June 2004 09:21 Go to previous messageGo to next message
hey gianttomato
the abs signal is the proper one for th eauto to change gears
the signal form the speedo to both ecus is the backup signal
it will change gears on the backup signal but it wont be accurate
ive had mine from one extreme to another
from to early to to late changes
another prob is
if u get the speedo drive correct to get the speedo accurate then u have to hope that the signal is correct that goes to the ecus
this is the biggest dilema of runnin the auto of this signal from the speedo
u can only get one right either speedo or auto changes
unless u fluke it
to get the auto to change gears correctly by that i mean about 90 to 95 % correct my speedo was out
autos are a pain in the arse to get right
the way i have mine now is the speedo runs of elect speedo drive thru a ratio box to get correct
then the abs sensor thru another computer to the auto ecu
it uses this signal to change gears
it stil has the speedo drive signal to the auto ecu
but that signal makes the auto change gears on the redline after 2 or 3 seconds of redlining hehehe
but with the boxes im goin to get u can adjust them and control where the gear changes are
like a econ/power switch but much more adjustments
Re: 1UZ Crown wiring questions Fri, 18 June 2004 09:43 Go to previous messageGo to next message
Sideshow, the jigery/buggery box your making, will it allow the dumping of the abs ecu?
celica_freak
newcastle
Re: 1UZ Crown wiring questions Fri, 18 June 2004 15:10 Go to previous messageGo to next message
howdy
well im not sure about moving[havent got tailshaft yet] butthe motor starts and reves without the A.B.S, TRC,ABSORBER CONTROLLER, RADIATOR,HYDROFAN,AIR CON,AND REAR WIRING HARNESS.
when I get that far will be glad to tell all i have learned
hope u do the same if u get there first.
celica_freak
newcastle
Re: 1UZ Crown wiring questions Fri, 18 June 2004 15:35 Go to previous messageGo to next message
this helps me heaps thanks all.
well side show have u got a price in mind for your box?
and where would it plug into.inside the car or out with the box if with box how big is your box.
Toobs
Re: 1UZ Crown wiring questions Fri, 18 June 2004 16:14 Go to previous messageGo to next message
celica_freak wrote on Sat, 19 June 2004 01:35
Thats sort of a personal question... JK
Seriously though I would be interested to see how this thing works...
If its just a pulse frequency divider / multiplier it would be quite simple to make!
sideshow
Re: 1UZ Crown wiring questions Fri, 18 June 2004 23:40 Go to previous message
well i buy the boxes
and i just set them to a certain spec
i just make about 15% on the price
just so it covers all my research
at the moment i havnt had time to test it without abs
no time to do things when yr booked 2 weeks in advance
but at the moment its running perfect
i have ordered a workshop manual for my crown too
it all in japanese but the pics should help
hope to get it soon
im not to sure but i think because i had no abs signal to auto ecu it might have been pinging
i only got it running righ tthe other day
so in a week or so ill let u knpow if the pinging is fixed and if it has better fuel economy
but now i get no check engine light or o/d light coming on telling me theres errors
the boxes are bout 200 bucks
by the time i go and get them and shit
but i will ask for a discount this time if i buy them in bulk
Previous Topic:Toyota Soarer CD stacker
Next Topic:Immobiliser points (4afe)
Current Time: Sat Nov 21 04:31:50 UTC 2026
Total time taken to generate the page: 0.0081748962402344 seconds
