Toymods » Tech & Conversions » Working a silvertop 20V
Simon-AE86
Banned user
ADELAIDE - The Drift City
Working a silvertop 20V Thu, 17 June 2004 11:43 Go to next message
this is for a friend. Got a 20V silvertop,what can be done SIMPLY to add extra HP, can you change the cams in them to some 272's or something with stock ecu?
tellme how to get this motor screaming with the stock ECU for least $$$ possible without using NOS Wink
Simon-AE86
Banned user
Re: Working a silvertop 20V Thu, 17 June 2004 12:37 Go to previous messageGo to next message
carn!
ae86drift
sydney.au
Re: Working a silvertop 20V Thu, 17 June 2004 12:40 Go to previous messageGo to next message
i dont think you can upgrade cam without ecu upgrades on a 20v
vvt interferes i think
unless you turn it off that is..
afm or map ?
Simon-AE86
Banned user
Re: Working a silvertop 20V Thu, 17 June 2004 22:04 Go to previous messageGo to next message
thought all silvertops were AFM? whioch would mean larger cams would be easier to use on the stock ecu.
switching VVT off isnt too much of a drama i spose.
Johnny
Sydney, OZ
Re: Working a silvertop 20V Fri, 18 June 2004 00:27 Go to previous messageGo to next message
apart from Exhaust and A/F.... Nil
If your gunna to do that, they're worst than a 100Kw.... don't know where people get the Idea from... only way to get more power from these is rip the head rip, port, shave... if you want cams, well you'll need and A/M ECU to advance them at a different rpm. Tried and True method. Decent cams for these also cost $1100, not incl cam gear to dial them in properly
Re: Working a silvertop 20V Fri, 18 June 2004 00:57 Go to previous messageGo to next message
exactly! VVT is there so that at LOWER rpm you have MORE torque and power!!! without VVT, it's just a cammed 100kw with an extra valve and quads. low-mid range will suffer..
the 20V's already have pretty good torque (ie close to as much as possible) so abotu all you can do is move the torque band upwards and get more POWAH...
as Johnny said:
exhaust, air filter, then expensive internal mods.
or turbo Wink
EvilJack
Sutho/Hills NSW
Re: Working a silvertop 20V Fri, 18 June 2004 01:26 Go to previous messageGo to next message
i'd say this would be one way to do it
http://www2.msstate.edu/~sgn1/MR2/mod/rh.htm
Rolling Eyes
Re: Working a silvertop 20V Fri, 18 June 2004 01:49 Go to previous messageGo to next message
http://www.toda-racing.co.jp/product/parts_e/cam/4ag5v-1.jpg
http://www.toda-racing.co.jp/product/onemake_e/4ag /4ag-02.html
Johnny
Sydney, OZ
Re: Working a silvertop 20V Fri, 18 June 2004 06:13 Go to previous messageGo to next message
very nice cams.... I use the 264 9.0mm IN/EX, but a standard S/T they made bugger All difference til we did the head work.... Truefully, We get B/T and S/T with Microtech, Pulling 115-120WHp, just with a port, shave and a well setup exhaust system, standard bottom and cams.....
bass_boy
Re: Working a silvertop 20V Sat, 19 June 2004 00:43 Go to previous messageGo to next message
Pulling 115-120WHp.. is that an at the wheels figure?
ae86drift
sydney.au
Re: Working a silvertop 20V Sun, 20 June 2004 06:15 Go to previous messageGo to next message
gianttomato wrote on Fri, 18 June 2004 11:49
toda 288 degree cams on a 20v sound like sex on a stick
mmmm
Johnny
Sydney, OZ
Re: Working a silvertop 20V Sun, 20 June 2004 09:10 Go to previous messageGo to next message
Quote:
WHp
=Wheel Horse Power
corolla madness
Re: Working a silvertop 20V Sun, 20 June 2004 10:54 Go to previous messageGo to next message
Sounds sort of alright considering i had my standard 20v dynoed at 93hp at the wheels.
sr54wdcorolla20v
August 2005
Re: Working a silvertop 20V Sat, 13 August 2005 09:41 Go to previous messageGo to next message
Johnny wrote on Fri, 18 June 2004 16:13
excuse my ignorance but what does B/T and S/T mean?????
STR8 2.8
Re: Working a silvertop 20V Sat, 13 August 2005 09:48 Go to previous messageGo to next message
blacktop and silvertop?
ae86drift
sydney.au
Re: Working a silvertop 20V Sat, 13 August 2005 09:52 Go to previous messageGo to next message
STR8 2.8 wrote on Sat, 13 August 2005 19:48
correct
and no (omg this thread is old) but 20v's came in 2 formats
earl;y and late
early ones had AFM
older ones had MAP
the older ones werent AE101 sedan's tho
they came in an ae101R wagon released in 1995 (yes the yeaf of release of the blacktop) and nothing else
these waghon engines are rumored to be the basis of the TRD group a engines.. having SOME ae111 parts and SOME ae101 parts
so that answers simons question (if somewhat late) Smile
JNR 13B
Re: Working a silvertop 20V Sat, 13 August 2005 11:15 Go to previous messageGo to next message
ok questions
Is the 20v and 16V Adjustable cams gears are both the same?
is the any benifit by just putting adjustable cams gears only?
and by just putting cams in the engine, do i need to replace value springs or and things else in the engine?
I do have an after maket ecu.
JNR 13B
Re: Working a silvertop 20V Sat, 13 August 2005 11:18 Go to previous messageGo to next message
what size In and Ex is the best for power
sr54wdcorolla20v
August 2005
icon10.gif  Re: Working a silvertop 20V Sat, 13 August 2005 11:40 Go to previous messageGo to next message
Thanks, that was gonna be my next question.
Hey Jonny, How much do you shave off the 20v heads what sort of Microtech. I have 20v in corolla 4wd wagon. Wahoo
Johnny
Sydney, OZ
Re: Working a silvertop 20V Sun, 14 August 2005 08:52 Go to previous messageGo to next message
one the Blacktop, nothing, just a clean up and a TRD 0.8 mm gasket and the Silvertop, very little ( 1 thou max) and the same gasket (TRD 0.8mm). But it also depends on fuel. As for the ECU, any aftermarket one will do.
Which engine are you talking about? If it the B/top,Yes the AE101R wagon did come with it as this is where I got mine from; BZ touring and also the GT sedan... the Hatch was quickily phased out by 1995 as it didn't sell for some reason and never got the late model 20V's
Not 100% sure, but just get the ones to suit your engine
Yes, but very not a great amount
Depends on lift duration and redline. Any different cams will need the correct shims, but some will be fine with standard shim etc. Clearences will always need to be checked, and unfortuately, this will be after a dumby fit.
JNR 13B
Re: Working a silvertop 20V Mon, 15 August 2005 06:17 Go to previous messageGo to next message
ok then
here is a question
do i have any benifit from putting a Black top 20v cams and cam gears on to my silver top?
is there any thing in the black top i can us eto benifit me?
Johnny
Sydney, OZ
Re: Working a silvertop 20V Mon, 15 August 2005 06:44 Go to previous messageGo to next message
Talk to me in a few more weeks as this is exactly what we are doing ie Blacktop Cams, Throttles and manifold on to a S/top. So far I haven't heard any thing about this setup; only B/top on B/top or S/top on S/top. I'm just lucky that I have a couple of each sitting around and with a S/top currently going into the rally car for next year's comp, this would be the best time to find out. First run is going to be the standardish setup's that are outlined above, then we'll fit the B/top gear to the same engine and see what the dyno tells us, and it should as the B/top cams are a have more lift and more duration then the S/top's, so this should give some changes. The throttles, well, I think that they won't make the greatest of difference, but it'll be worth seeing anyway.
Sam_Q
S.E suberbs, Vic
Re: Working a silvertop 20V Tue, 16 August 2005 14:29 Go to previous messageGo to next message
it would be awesome if you could do that Johnny, it would lay some debates to rest for sure. Also I though it was only the intake that had 0.5mm more lift on a blacktop and a 5 degree later duration.
Johnny
Sydney, OZ
Re: Working a silvertop 20V Tue, 16 August 2005 16:07 Go to previous message
You are right on that, exhaust is identical to the silvertop. I keep forgetting it's another engine that where running identical cams with higher lift,(256deg 9.0mm lift in/ex) this is going into a Brand spanking new rally shell...GARC here we come Very Happy
Previous Topic:EMS 8860 query
Next Topic:13T ignition parts?
Current Time: Tue Oct 27 08:33:20 UTC 2026
Total time taken to generate the page: 0.048649072647095 seconds
