Toymods » Tech & Conversions » Help with 2T Carby
manipulate
Help with 2T Carby Wed, 04 September 2002 12:26 Go to next message
hey all
When looking at the Carby on my 2T from the driver side of the engine bay....there are 3 screws .....i know 1 of them (middle-ish one) sets the idle through the throttle.....but what do the other 2 do ???
Cause i messed arouind with the one on the furthest right and now it seems as though im chugging more fuel....(imagination??)
ta ppl
Smile
(woops....can someone pls move this to the tech section ....soz)
[Updated on: Wed, 04 September 2002 12:27]
Classique71
Colac, Victoria
Re: Help with 2T Carby Wed, 04 September 2002 13:59 Go to previous messageGo to next message
Ones for your fuel air mixture i knwo thast much - theres a third i think near the bit where your linkage comes in to connect to the carby that adjusts when your secondary throat opens up .. Gimme a bit iof time and ill try to ahve a peek at my spare 2t carbs in vic .. Ill eb moving down there saturday week ...
sounds of it you have your carb runnign way too rich ..
manipulate
Re: Help with 2T Carby Thu, 05 September 2002 08:50 Go to previous messageGo to next message
OK much appreciated
manipulate
Re: Help with 2T Carby Fri, 06 September 2002 01:03 Go to previous messageGo to next message
So how would u tune the air\fuel mix....cause when i was playing round with it i left on the setting that makes it rev a little higher when ideling....this is obviously wrong....how do i do it ??
ta
GIN51E
Berowra-Sydney
Re: Help with 2T Carby Fri, 06 September 2002 01:09 Go to previous messageGo to next message
i have no idea about carbs i only know about webers and those tiny little carbs on RC cars but all i can say is one is for the idle speed, (got nothing to do with mixture) one would be for the fuel air mixture and if they are like webers then the last one would be to do with the idle air/fuel mixture.
but could be your imagination as whenever i touch my engine my brain plays tricks on me thinking it might be going faster or slower now.
sorry i'm not much help but i just enjoy getting my post count higher Razz Razz Razz
Re: Help with 2T Carby Fri, 06 September 2002 03:37 Go to previous messageGo to next message
Tuning carbies is not a job for the backyard tinkerer - you really need to have the right equipment (eg exhaust gas analyser) and plenty of experience to do it properly. If you just turn screws at random you're not likely to acheive much apart from making your engine run like crap...
manipulate
Re: Help with 2T Carby Fri, 06 September 2002 06:09 Go to previous messageGo to next message
Nah anything is a help to me GIN5IE
hmm...its definetely chugging more fuel
How much for one of those exhaust gas analysers and where from ??
ta ....
Re: Help with 2T Carby Fri, 06 September 2002 06:40 Go to previous messageGo to next message
Exhaust gas analysers cost several times what your car is worth - they're the sort of things that only specialised workshops own.
manipulate
Re: Help with 2T Carby Fri, 06 September 2002 06:43 Go to previous messageGo to next message
hmmm..ok....so theres nothing i can do for now ??
M.W.P.
Rocky Mountains, Canada
Re: Help with 2T Carby Fri, 06 September 2002 07:41 Go to previous messageGo to next message
It is possible to tune a carb without an EGO sensor but its difficult and can take a long time.
If you still want to do it yourself, go into Jaycar and buy a EGO sensor display. Then either buy a 3wire EGO sensor and pop lay it in the end of your exst pipe while testing, or get a single wire sensor and weld a bung into your exst manifold.
There are then quite a few guide around the net for tuning with a EGO sensor.
GIN51E
Berowra-Sydney
Re: Help with 2T Carby Fri, 06 September 2002 07:52 Go to previous messageGo to next message
yeah you can get fuel mixture senses from jaycar but they don't recommend using them with cars running on LRP because the bugger up the sensor over time but if you install it for just when u want to try and tune it then that should be ok and not stuff the sensor. but make sure you have no exhaust leaks or holes otherwise you will get a faulse reading Shocked
manipulate
Re: Help with 2T Carby Fri, 06 September 2002 08:33 Go to previous messageGo to next message
k sweeters
much appreciated
im running on premium anyway
Jonny2TG
Tasmania
Re: Help with 2T Carby Fri, 06 September 2002 15:26 Go to previous messageGo to next message
OK, I am a mechanic and just stripped down and rebuild a 2T carbie and tuned in on the car.
From the drivers side, the front screw is the idle mixture screw. If this is too far open, the car will run fine but you will go through alot of fuel. Running Premium is probably a waste also on this engine, normal unleaded is fine. This idle mixture screw should be screwed closed (lightly), then backed off 1-1/2 turns to start with. You can then adjust by ear, so the engine is running just slighlty slower than the fastest position.
The middle screw is the idle speed. It acts on a throttle stop, to keep the throttle cracked open to idle. Adjust this however you like, but probably so the engine runs at about 800rpm, or at 1000rpm if you have mods.
The left screw adjusts the position of the choke breaker. When you floor it, the choke is opened at bit by this lever if it isn't already open. Don't worry about this one much.
M.W.P.
Re: Help with 2T Carby Fri, 06 September 2002 16:12 Go to previous messageGo to next message
GIN51E wrote on Fri, 06 September 2002 17:22
yeah you can get fuel mixture senses from jaycar but they don't recommend using them with cars running on LRP because the bugger up the sensor over time...
You sure they say LRP??
I know that lead fouls the EGO sensors quickly, but of course LRP doesnt contain lead.
GIN51E
Berowra-Sydney
Re: Help with 2T Carby Fri, 06 September 2002 23:09 Go to previous messageGo to next message
i was told that the additive that replaces the lead also fouls up the sensor which i tend to believe as it tends to stuff everything else up as well....
BRING BACK LEAD! Evil or Very Mad
manipulate
Re: Help with 2T Carby Sat, 07 September 2002 01:22 Go to previous messageGo to next message
I knew there was a way to do it myself
Thanx Johnny
Smile
Exclamation
M.W.P.
Re: Help with 2T Carby Sun, 08 September 2002 13:06 Go to previous messageGo to next message
GIN51E wrote on Sat, 07 September 2002 08:39
Just reading your sig... did you realise that the 18RC has hardened valve seats? You can run ULP and PULP in that fine.
GIN51E
Berowra-Sydney
Re: Help with 2T Carby Sun, 08 September 2002 21:44 Go to previous messageGo to next message
i got mine dyno tuned on LRP and since then i put a tank of premium in for the celica cruise and it made the car run like shit and once i filled it up with LRP again it ran like a dream,
M.W.P.
Re: Help with 2T Carby Mon, 09 September 2002 15:43 Go to previous message
Now thats kinda odd.
Oh well, next dyno tune you get done go for PULP.
Previous Topic:torque setting for 4AGZE head bolts?
Next Topic:HELP: Greasy boots !
Current Time: Fri Nov 20 09:23:59 UTC 2026
Total time taken to generate the page: 0.0070211887359619 seconds
