Toymods » Tech & Conversions » e/win
Mentor
vic
e/win Tue, 21 May 2002 12:05 Go to next message
has anybody ever installed or tried to install electric mirrors and windows from a supra into a RA6x? I plan on swapping the doors over aswell.
thetoyman75
Club President
Re: e/win Tue, 21 May 2002 12:16 Go to previous messageGo to next message
Mentor I have no idea but canyou do a test fit at the local pull a part type wreckers ? I know Pick and Payless has seen many a theory tested for me Smile
BTW is your avatar actually your car ?? The front looks sweet !
Re: e/win Wed, 22 May 2002 08:38 Go to previous message
Dude, easiest thing in the world! Sort of... Razz
Took me about 45 mins to do each door properly. Plus all the stuffing around in the first place for the wiring.
Basically, you'll need all the wiring, because none of the power window wiring was in my RA60, although it may be on yours.
If not, you have to separate all that from the loom in the Supra.
Next you need to rip the guts out of the Supra doors. Quite simple, remove the trim etc. undo the stoppers at the top and disconnect window nuts from mechanism. Slide the window out, disconnect the electric mechanism. Do the same to yours and swap the mechanisms over. Put her back together and swap the door looms over.
If you have no window wiring like me, you have to just ground the window loom and connect power (either ignition or constant like me) and bobs ur uncle. Make sure you have the Supra door panels with the switches, and if you have speakers mounted in your doors, they require relocating or cutting of metal because the Supra panels dont like up with the factory holes.
If you get stuck, contact me on here. Good luck.
Previous Topic:ke-35: Getting air out of brakes
Next Topic:TA23 struts
Current Time: Fri Nov 20 16:15:28 UTC 2026
Total time taken to generate the page: 0.003734827041626 seconds
