Toymods » Tech & Conversions » Conversion effect Speedo??
KOFFEE-BLACK
Conversion effect Speedo?? Fri, 18 June 2004 15:46 Go to next message
Hey guys, will the 1JZGTE effect the use of the standard IS200 Speedo?? I was speaking to a chap in Japan, (altezza drift club) he says, his friend with the 1JZGTE in his Altezza, the Speedo wasnt working correctly. Please Help!
I also, want to get this: http://www.trdparts.jp/parts_fullscalecomb.html
But have no idea where to get them from. Kristian??!!!!
Cheers!
sideshow
Re: Conversion effect Speedo?? Fri, 18 June 2004 23:41 Go to previous messageGo to next message
is the speedo electronic or cable
either way there are devices to adjust them to calibrate the speedo accurately
Re: Conversion effect Speedo?? Sat, 19 June 2004 02:23 Go to previous messageGo to next message
No the 1JZ-GTE will have no effect at all since the speedo is hooked up to the transmission, not the engine! Perhaps you should tell us which transmission you're going to be using with your 1JZ-GTE.
takai
Re: Conversion effect Speedo?? Sat, 19 June 2004 02:54 Go to previous messageGo to next message
You can use a V160 from the Au IS300. Or a R154, with the electronic speedo output from the IS300.
Re: Conversion effect Speedo?? Sat, 19 June 2004 02:59 Go to previous messageGo to next message
The IS300 does not have a V161. In fact I don't think it even has a manual transmission option? In any case, the V161 has only ever been available in the JZA80 Supra.
The IS200 has a 6-speed manual but that's a completely different beast and won't bolt up to a JZ engine.
takai
Re: Conversion effect Speedo?? Sat, 19 June 2004 03:56 Go to previous messageGo to next message
True true, brain hurts. I think the Altezza or a JDM model comes with a V161. It shows up like that in the EPC anyway, although it specifies a V160.
Bit confusing.
KOFFEE-BLACK
Re: Conversion effect Speedo?? Sat, 19 June 2004 04:11 Go to previous messageGo to next message
Ahhh ok! Im using a jZA80 W58.
The US spec IS300 has a manual gearbox, but im 99% sure its not the V160
Cheers Guys!
Re: Conversion effect Speedo?? Sat, 19 June 2004 05:10 Go to previous messageGo to next message
No, it's a W58 5-speed.
The Altezza has a 6-speed box but that's the same one as the IS200, ie NOT the Getrag.
deesonet
Toowoomba
Re: Conversion effect Speedo?? Sat, 19 June 2004 06:32 Go to previous messageGo to next message
The IS200 manual is a J160 which is a baby version of the V160. It won't fit directly onto a 1JZ - would require an adaptor plate. Anyway with the plague of IS200 2nd gear problems it wouldn't handle the power.
The V160 fitted into my IS200 uses the same speedo drive as the J160 which came out. Exactly the same right down to the part number and same electrical plug on the end.
Not sure of the W58 but would assume that Toyota has standardised on the same drive for all of the gearboxes.
KOFFEE-BLACK
Re: Conversion effect Speedo?? Sun, 20 June 2004 00:31 Go to previous message
Cool! Thanks for that Guys! Hmmm, wouldnt mind the V160, but running out of $$$$
Previous Topic:st185 halfcut pricing in Vic?
Next Topic:5m-ge wiring diagram - please help!
Current Time: Fri Nov 20 09:00:31 UTC 2026
Total time taken to generate the page: 0.0052690505981445 seconds
