Toymods » Tech & Conversions » What oil to use?
Corolla Boy
icon4.gif  What oil to use? Wed, 04 September 2002 14:47 Go to next message
I own I 1987 4ac Corolla. The previous owner used 25w/40. Repco advised me to use 25W/70. Ever since I used the 25W/70 oil I realised the engine has become very noisy (I think its the tappets or lifters) before the oil change the engine use to be noisy only when cold, but now its noisy all the time. The service book recommends using Castrol GTX which is a 15W/40 or 20W/50. Summer is comming up and I want the best protection and least noise from the engine. I sometimes don't have time to warm up the engine 2 times per day so I drive while the engine is still cold. What oil should I use?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: What oil to use? Wed, 04 September 2002 14:58 Go to previous messageGo to next message
Since the weather's started warming up, a thicker oil would be a bit better. You may find on warm days when the engine gets really nice & hot it shouldn't be so noisy.
I was using a 5W-40 oil through winter, & have now changed to a 15W-50, but my engine rarely runs very hot because the radiator works too well. During winter, my car will never reach full operating temperature while driving. I can let it warm up, but once start moving it drops straight down to 60 or so degrees.
The best solution I came up with was to cover half the radiator with a peice of cardboard painted back. Bodgy but effective.
gt20v
Re: What oil to use? Thu, 05 September 2002 14:19 Go to previous messageGo to next message
Bigworm: sounds like you have a stuck open thermostat, or maybe you don't even have a thermostat, as running the engine around 60 degrees is not good news, I think the ECU runs in open loop until the engine warms up, the mixture would be rich before it reaches 80-82 degrees which is ideal..
BigWorm
Turramurra, Sydney.
Re: What oil to use? Thu, 05 September 2002 17:43 Go to previous messageGo to next message
Nah, it's definitely not the 'stat, I tried getting a hottor one to try & solve my probs, but could not get one anywhere (anyone know of one?). I even forked out for a genuine toyota one, in the hope that it may open at a more acurate 82, but still no luck.
It runs a microtech MT8, which does pretty much the same as the standard ECU, and richen the mixture according to the coolant temperature, so it was running hella rich during winter. It's starting to not be such a problem now, at least I won't have to worry this summer.
I think it just comes down to my 4A-GE having a bigger radiator than it was ever meant to, and the cooling system being a bit too efficient.
Grega
melbourne.victoria.austra...
Re: What oil to use? Thu, 05 September 2002 20:38 Go to previous messageGo to next message
out of interest what radiator did you put up front bigworm?
gt20v
Re: What oil to use? Fri, 06 September 2002 02:36 Go to previous messageGo to next message
Hi Bigworm, it shouldn't be the case as I'm using a radiator probably 3-4x of what my engine needs too, I'm running Microtech MTX-8, but the coolant should be trapped "inside" the engine when the water temp is below 82 degrees, so the radiator would have nothing to do with the coolant (that's only if the thermostat is working probably)
BigWorm
Turramurra, Sydney.
Re: What oil to use? Fri, 06 September 2002 02:53 Go to previous messageGo to next message
It's the standard RA-23 radiator, & it's been cleaned etc and is in very good nick.
gt20v: I underdstand how it's meant to work, it just doesn't like it should. There can be no way the 'stat isn't working properly, I've replaced it enough times.
From the way I see it, the water in the motor is at 82 (or close enough) and starts flowing out, and the water coming into the motor from the radiator is much cooler & manages to bring down the temp at the temp probe (other end of the motor to the 'stat).
gt20v
Re: What oil to use? Fri, 06 September 2002 12:21 Go to previous messageGo to next message
but 60 degrees sounds too strange.. Very Happy
GIN51E
Berowra-Sydney
Re: What oil to use? Fri, 06 September 2002 13:45 Go to previous messageGo to next message
am i just dreaming this or is there an electronic thermostat available? where you can adjust how much it opens by the twist of a knob? Rolling Eyes
gt20v
Re: What oil to use? Sat, 07 September 2002 01:58 Go to previous messageGo to next message
well... would you pay for a $200 electronics thermostat? Razz
GIN51E
Berowra-Sydney
Re: What oil to use? Sat, 07 September 2002 08:08 Go to previous message
well to be honest i probably would Razz i tend to be good at wasting money,
Previous Topic:4 AGZE convertion
Next Topic:Sprinter/4age help
Current Time: Wed Oct 28 08:11:54 UTC 2026
Total time taken to generate the page: 0.0045981407165527 seconds
