Toymods » Tech & Conversions » do panhard rods effect handling?AE86
45aken
NSW.south coast.Drifting
do panhard rods effect handling?AE86 Sat, 19 June 2004 06:20 Go to next message
will the $114 whiteline adjustable panhard rod affect the handling of my car? will it stop the axle from moving from side to side?
Re: do panhard rods effect handling?AE86 Sat, 19 June 2004 06:26 Go to previous messageGo to next message
that depends on your ride height, the mounting positions of the rod etc etc...
it's a geometry thing, not an adjustability problem.. how much does it move now?
to STOP it moving side to side.. just fit a Watts link Wink
45aken
Re: do panhard rods effect handling?AE86 Sat, 19 June 2004 07:52 Go to previous messageGo to next message
well the car is "dumped to the weeds" but im having no problems with the wheels/axle being too far to one side. just thought it might have some sort of advantage.
Re: do panhard rods effect handling?AE86 Sat, 19 June 2004 09:11 Go to previous messageGo to next message
it's advantage is that it's adjustable in length, to adjust the location of the diff (as you should already know)
if the current one is the correct length, i think it's feckin pointless buying an adjustable one to be the same length..
unless of course it is the BLING factor??
panhard rods affect handling. of course. is yours the correct length now?
Satoshi
Re: do panhard rods effect handling?AE86 Sat, 19 June 2004 09:55 Go to previous messageGo to next message
i got a mate trying to install that panhard rod on his car..
all i can say is he has to remeasure remeasure remeasure adjust adjust..remeasure...hmmm..tricky little bugga
wilbo666
Re: do panhard rods effect handling?AE86 Sat, 19 June 2004 14:06 Go to previous messageGo to next message
bah, I just measured the gap on each side and adjusted it so that there was an equal amount on each side Rolling Eyes wasn't exactly rocket science, and it didn't take for ever.... Smile
that might have just been luck on my behalf tho Smile
45aken
Re: do panhard rods effect handling?AE86 Sat, 19 June 2004 18:34 Go to previous messageGo to next message
o well, im having no problems with my diff being out of center at the moment, i just thought it might stop it from moving from side to side.
meh....$114 saved
thanks all!
ae95
Re: do panhard rods effect handling?AE86 Sat, 19 June 2004 19:23 Go to previous messageGo to next message
take it to wheel alignment shop Smile
Karl_skewes
New Zealand
Re: do panhard rods effect handling?AE86 Sat, 19 June 2004 23:29 Go to previous messageGo to next message
yes.. if your diff's off to the side, then it won't turn both left and right evenly.
It's worth doing.
And it's a set and leave type deal..... lower car to desired height, set it.... done.
Fattony
Re: do panhard rods effect handling?AE86 Sun, 20 June 2004 03:57 Go to previous messageGo to next message
If your not having problems with your tyres rubbing guards or drive shaft hitting one side of the tunnel then it is not worth placing such an item on your car. Yes having an off-centre diff will effect the cars handling characteristics, but unless you put the car on a track, you should not be doing those sorts of speeds to find out the handiling difference on the street ;)lol.
ae86drift
sydney.au
Re: do panhard rods effect handling?AE86 Sun, 20 June 2004 08:10 Go to previous messageGo to next message
45aken
i have that bar
yes it makes a world of difference
slydar
Re: do panhard rods effect handling?AE86 Sun, 20 June 2004 08:57 Go to previous message
the stiffer bushes that come with the panhard bar should make your rear end feel a bit more solid. also its alot heavier built, so it should be stiffer. i noticed a slight differance in rear end feel when i fitted one to my last sprinter. as far as ajusting, its really easy to do, and doesnt take long at all, and once its done, its done.
Previous Topic:Alternator regulator on 93 camry
Next Topic:Steering Lock. How to change(if possible) MX83
Current Time: Fri Nov 20 14:32:39 UTC 2026
Total time taken to generate the page: 0.0070781707763672 seconds
