Toymods » General Car Talk » Seized my 2ZZ-GE
psychofox
Wollongong, NSW
Seized my 2ZZ-GE Sat, 19 June 2004 12:51 Go to next message
Don't you just love a post with a title like that....
driving along fairly quickly on a twisty road, I hear a knocking noise from the engine on my celica. I was a couple of kays from home - so I thought...I'll nurse it home slow and see what it is. Got about 500m down the road and the engine seizes. Trust me, it's the worst feeling in the world. Seeing the celica on the back of a tow truck wasn't something I want to replicate...
I had a look at some celica forums and apparently these engines have a bit of propensity to bend exhaust valves. That scares me - with all that variable lift stuff in there - it's probably going to need a new head, etc...I don't think it's going to be cheap to fix. Crying or Very Sad Crying or Very Sad Crying or Very Sad
V8_MA61
Re: Seized my 2ZZ-GE Sat, 19 June 2004 12:52 Go to previous messageGo to next message
id try and source another motor out of a wrecked car mate....its gonna be the cheapest at the end of the day!
psychofox
Wollongong, NSW
Re: Seized my 2ZZ-GE Sat, 19 June 2004 13:00 Go to previous messageGo to next message
you reckon? I That engine is going to be expensive. come to think of it, I can't recall ever seeing one at a wreckers - or a front cut.
I'll be ringing wreckers on monday though....
I'm just hoping the bottom end isn't too damaged. The bores on those motors are only 5.5mm apart, and they are metal matrix. Apparently you can't overbore them at all.
V8_MA61
Re: Seized my 2ZZ-GE Sat, 19 June 2004 13:06 Go to previous messageGo to next message
if its seized, you must have grabbed a bore with a piston or something..in which case throw away the engine!
Re: Seized my 2ZZ-GE Sat, 19 June 2004 13:33 Go to previous messageGo to next message
if you have to throw it away, would you like to donate it to charity Wink i'm keen to see how one of these could fit up to an old corolla Very Happy
if you can, pull the engine down and see whats wrong...
pull off cam covers and see if valves still move, then pull the head and see if the bottom end turns over..
yup, being an alloy block, the bores are usually high silicon and if overbored become much less wear resistant..
good luck!!
DiZ_
The Eastwood MASSIVE !
Re: Seized my 2ZZ-GE Sat, 19 June 2004 13:36 Go to previous messageGo to next message
Dam man , that is no good at all. Sad
Fieryisles
Re: Seized my 2ZZ-GE Sun, 20 June 2004 02:15 Go to previous messageGo to next message
Switch1 on the newcelica.org forum had his engine seize too. He misshifted and overreved the engine, then when toyota repaired it, they stuffed something up then it seized a few weeks later. They quoted him a fortune to fix it.
He ended up getting a complete new engine for 2.5k. Best of all it had only had 800m on the clock!!!
http://www.newcelica.org/forums/showthread.php?s=& amp;threadid=130792
The place that sourced the engine for him was called Bezerkly automotive (http://www.bezerkly.com/) and that may be your best bet to get things sorted if your car is not under warranty :)
Grega
melbourne.victoria.austra...
Re: Seized my 2ZZ-GE Sun, 20 June 2004 04:48 Go to previous messageGo to next message
speak with meridian motorsport they also get these engines.
Johnny
Sydney, OZ
Re: Seized my 2ZZ-GE Sun, 20 June 2004 09:16 Go to previous messageGo to next message
Quote:
if you have to throw it away, would you like to donate it to charity i'm keen to see how one of these could fit up to an old corolla
My thoughts exactly... make a good IP car Very Happy
ScreaminRolla
Campbelltown NSW
Re: Seized my 2ZZ-GE Sun, 20 June 2004 10:23 Go to previous messageGo to next message
i know of a few of these motors that have had there oil pumps fall to bits, which could have been the start of your probs, im guessing its not under waranty?
Rolla Boy
Club Member
Sydney, NSW
Re: Seized my 2ZZ-GE Sun, 20 June 2004 10:28 Go to previous messageGo to next message
2000 model Celica... 3 years warranty... Any chance you have extracare???
Either that or see a Toyota dealer and try a warranty approach... This will only go through if you have had all your services done at 10,000km intervals and never missed one...
We had an Avalon at work a few weeks ago... 40,000kms, never been serviced... Siezed... Oil sludgy as... Engine requires rebuild and no warranty...
Best bet for you if warranty is not an option, source a new head from Japan... That ofcourse if the head is the problem...
psychofox
Wollongong, NSW
Re: Seized my 2ZZ-GE Wed, 23 June 2004 10:09 Go to previous messageGo to next message
Just an update...
I took it to a toyota dealer - they pulled the motor out of the car, it has destroyed the big end bearing on No.1 Piston, and in doing so, damaged the rod, crank and main caps. Apparently the bores are ok. It is out of factory warranty 3yr/100000km) but the dealer is putting in an out of warranty claim on toyota (as the car only has 68000kms on it) to see if they can get the cost of fixing it paid by them.
I have been told to fix they have to replace the entire short motor (it's cheaper than buying a crank, caps, rods and assembling it) and that is going to cost $3500 (ballpark). The head is apparently ok...thankgod. I'm going to go and have a look at it tomorrow - If I can I'll take some pics.
Re: Seized my 2ZZ-GE Wed, 23 June 2004 11:39 Go to previous messageGo to next message
Fingers crossed that you get it paid for!
Very Happy
so... do you get to keep the block??
if so, i'll give you a few $$ for it (or borrow?) and you keep all good bits...
i am really really keen to see how these fit in KE10's Smile
good luck with it!!
EVOSTi
cambo
      no
Re: Seized my 2ZZ-GE Wed, 23 June 2004 12:02 Go to previous messageGo to next message
they wont give him any of the old parts. but you might be lucky and theyll pay for it, i know honda do it alot, better for their reputation but i dont remember toyota doing it when i worked at one of their dealerships. Rolling Eyes
Soarer
Wollongong
Re: Seized my 2ZZ-GE Thu, 24 June 2004 00:19 Go to previous messageGo to next message
Toyota didn't even want to talk to me when mine was 6 months out of warranty, only had 60,000km on it and the engine 'blew'.
psychofox
Wollongong, NSW
Re: Seized my 2ZZ-GE Thu, 24 June 2004 02:04 Go to previous messageGo to next message
I doubt I'll ever get to keep the dead parts.
Why would you want to put this in a KE10? Isn't a KE10 rear wheel drive? No RWD gearbox exists to bolt up to this, so you'd need to make a custom bellhousing, etc...
RobST162
Re: Seized my 2ZZ-GE Thu, 24 June 2004 02:08 Go to previous messageGo to next message
this is not the first time I have heard of 2ZZs loosing the plot pretty early in life..
sux dude
Camry_omega
Campbelltown, NSW, Austra...
Re: Seized my 2ZZ-GE Thu, 24 June 2004 07:29 Go to previous messageGo to next message
You could put a 3s-fe in it, mines done 206,000 and hasn't siezed.
Seriously that really sucks, it might be a common design flaw.
cambelt
melb
Re: Seized my 2ZZ-GE Thu, 24 June 2004 09:10 Go to previous messageGo to next message
Push the toyota dealer hard, if they dont do anything 4 u ring the toyota head office cust assistance line, toyota are norm petty good about just out warranty claims
Re: Seized my 2ZZ-GE Thu, 24 June 2004 13:30 Go to previous messageGo to next message
bugger.
Very Happy because i like to be a little different, amd the spec of the motor appeal to me.. 180Nm at 6000+rpm, current emissions.
and this is a problem how? Wink
psychofox
Wollongong, NSW
Re: Seized my 2ZZ-GE Fri, 25 June 2004 06:39 Go to previous messageGo to next message
Good news guys...very good news.
Toyota is covering the parts for the engine 'malfunction'. Which is $6500 worth of parts. I have to pay the labour, $1700. Pretty good dor a car 1 year 2 months out of warranty...
I was pretty pleased (a bit of an understatement). Apparently I'll have the car back end of next week/early the week after.
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Seized my 2ZZ-GE Fri, 25 June 2004 11:36 Go to previous message
so what was the cause?
Previous Topic:RA65 Speakers
Next Topic:S13 dune buggy
Current Time: Sun Oct 18 21:05:04 UTC 2026
Total time taken to generate the page: 0.012580156326294 seconds
