Toymods » Tech & Conversions » 18rg cylinder head airflow what cfm can it flow does anyone know
noodles
  noodles
18rg cylinder head airflow what cfm can it flow does anyone know Sat, 19 June 2004 17:38 Go to next message
Hi iam new to this form frist post. Anyone know what the 18rg cylinder head airflow cfm is. Stock and race spc.What would the cfm be with 45mm inlet valves and 38.5 exe valves stage 3 port egg.With a cam lift of 0.426in 10.8mm 295 duration.
wil8115
Seattle area, USA
Re: 18rg cylinder head airflow what cfm can it flow does anyone know Mon, 28 June 2004 07:51 Go to previous messageGo to next message
noodles wrote on Sat, 19 June 2004 10:38
stock cams are 240 degree duration at 50thou lift. and lift is 9mm or so. stock valves are 46/38 i think so not much gain there if any. the porting would be the biggest difference i'd see.. only one way to find out have it gas flowed.
I can have heads flow benched here.. but it's $80us per hr and i'm in da states..
Mr DOHC
Re: 18rg cylinder head airflow what cfm can it flow does anyone know Mon, 28 June 2004 09:21 Go to previous messageGo to next message
r u sure about the 240 deg part, my new cams are 233
wil8115
Seattle area, USA
Re: 18rg cylinder head airflow what cfm can it flow does anyone know Mon, 28 June 2004 09:34 Go to previous messageGo to next message
Mr DOHC wrote on Mon, 28 June 2004 02:21
not for sure for sure. just going on what ive been told by other people the stock RG cams aren't that whimpy.. I suppose i could have some spec'd tho. With only a carb change and later on a better Exhaust from manifold out.. my RG had W A Y more power. the stock 40's are a choke on the power for sure..
Re: 18rg cylinder head airflow what cfm can it flow does anyone know Mon, 28 June 2004 12:15 Go to previous messageGo to next message
TRD didnt mind the Solex's though....
wil8115
Seattle area, USA
Re: 18rg cylinder head airflow what cfm can it flow does anyone know Mon, 05 July 2004 22:53 Go to previous messageGo to next message
THE WITZL wrote on Mon, 28 June 2004 05:15
they didnt mind them? whaaa?!?!? all the writes up ive seen said they swapped to 40 or 44 "PHH" carbs or bigger and the "original Solexes" aren't rebuildable.. that was from a TRD catalog.
Mr DOHC
Re: 18rg cylinder head airflow what cfm can it flow does anyone know Wed, 07 July 2004 09:47 Go to previous messageGo to next message
wil8115 wrote on Tue, 06 July 2004 08:53
odd... i got mine rebuilt
munki
Gold Coast
Re: 18rg cylinder head airflow what cfm can it flow does anyone know Thu, 08 July 2004 02:34 Go to previous messageGo to next message
i think by non rebuildable they mean most parts are fixed except for main and slow jets.
wil8115
Seattle area, USA
Re: 18rg cylinder head airflow what cfm can it flow does anyone know Thu, 08 July 2004 09:01 Go to previous messageGo to next message
Mr DOHC wrote on Wed, 07 July 2004 02:47
Not all weren't rebuildable just the early ones(
"original solexes") but a phh will out perform it..
Mr DOHC
Re: 18rg cylinder head airflow what cfm can it flow does anyone know Thu, 08 July 2004 10:10 Go to previous messageGo to next message
maybe they meant they wrent worth rebuilding
useless POS's Mad
wil8115
Seattle area, USA
Re: 18rg cylinder head airflow what cfm can it flow does anyone know Thu, 08 July 2004 10:23 Go to previous message
Mr DOHC wrote on Thu, 08 July 2004 03:10
useless POS's Mad
LOL actually for the later ones i can get rebuild kits for under $100us for the pair.
the early ones are good paper weights..
Previous Topic:18rgu 253 series valve diameter?
Next Topic:ae86 master cylinder
Current Time: Sun Nov 1 20:12:45 UTC 2026
Total time taken to generate the page: 0.004849910736084 seconds
