Toymods » Tech & Conversions » The G wont start.. (1g geu) any hints?
Jag7799
The G wont start.. (1g geu) any hints? Mon, 21 June 2004 08:34 Go to next message
Okay ive been trying to start this car all day.. its my old GZ10 soarer with the 1g geu and hasnt been started since i got my 1jz.. and ive tried many times but wont start
the last time it ran it started fine but over time you had to hold the ignition on.. would sit for about 4 seconds doing nothing before turning over and starting normally
now ive taken the power steering lines out of it and just taken the induction piping off it but put all induction back on and started fine after that.
checked for spark, has that, fuel pump sounds to be working so im assuming it has fuel and as for air.. theres no reason why it wouldnt be getting that.
checked all fuses and they are all fine
battery was dead but has been charged and it does kick over as stated..
none of the loom has been unplugged since
could i maybe have fucked the AFM?.. and is there any way to bypass that just to see if it starts?
any other idea's?
My parents want me to get it starting so they can move it whenever
V8_MA61
Re: The G wont start.. (1g geu) any hints? Mon, 21 June 2004 09:23 Go to previous messageGo to next message
it still could the battery johal...i remember when wilbo and i picked up our sa63 it wouldnt start for a looong amount of tries...it eventually did. Its usually pretty hard to bring back a deceased battery thats all!
Dad's falcon one is dying, and if the car is left for 3-4 days at a time, it wont start either.
Blake
Jag7799
Re: The G wont start.. (1g geu) any hints? Mon, 21 June 2004 10:04 Go to previous messageGo to next message
but it turns over and has plenty of spark
joecoolmk2
Re: The G wont start.. (1g geu) any hints? Mon, 21 June 2004 10:22 Go to previous messageGo to next message
where did you check the fuel supply? check it at the fuel filter. if it has fuel then maybe there is something that's not connected somewhere, maybe an earth or something to do with the injectors.
Jag7799
Re: The G wont start.. (1g geu) any hints? Mon, 21 June 2004 10:34 Go to previous messageGo to next message
i didnt fully check fuel.. just that the fuel pump was making its usual noise
and nothing has really changed so i dont see why an earth would be gone
i will check it at engine though later in week
easiest way to check injectors?
Re: The G wont start.. (1g geu) any hints? Mon, 21 June 2004 10:39 Go to previous messageGo to next message
remove cold start injector, place spray end in large jar, turn ign on and see if squirting
well tell you if you have enuf fuel pressure
joecoolmk2
Re: The G wont start.. (1g geu) any hints? Mon, 21 June 2004 10:42 Go to previous messageGo to next message
you'll have to take them out, there's no easy way. if they aren't working then back track. check all your circuits with a multimeter. how did you check for spark? usual lead on head?
Jag7799
Re: The G wont start.. (1g geu) any hints? Mon, 21 June 2004 11:29 Go to previous message
yeah usual lead on head... ill get onto the cold start injector in a few days when i get some more time off
doing stuff at night with crap all light is annoying
Previous Topic:AE86 chronic axle tramp
Next Topic:Whiteline for ae86
Current Time: Wed Oct 28 06:10:53 UTC 2026
Total time taken to generate the page: 0.011053085327148 seconds
