Classifieds » Parts Wanted » "Piggy back sensor" for 1JZ speedo
woofa347
Whyalla
"Piggy back sensor" for 1JZ speedo Mon, 21 June 2004 09:52 Go to next message
Im looking for a "piggy back sensor" that is used to hook up the 1JZ's electronic speedo to the MX73 Cressida cable speedo.
woofa347
Whyalla
Re: "Piggy back sensor" for 1JZ speedo Wed, 30 June 2004 13:43 Go to previous messageGo to next message
Peeweee from Toyotacressida forums said that a guy named Grant makes them, or would know where I could get one from?
Any ideas? Can someone help me out, I really need to get the seensor so I can finish my 1JZ conversion Crying or Very Sad
mx83toy
Re: "Piggy back sensor" for 1JZ speedo Wed, 30 June 2004 15:23 Go to previous messageGo to next message
my mx83 has a cable speedo which conected straight to the 1J auto the mx83 has a wire from the dash speed signal wire which i hooked upto the computer to get the auto to shift...i'm quite sure that the 73 is the same????dont they have an electronically controlled auto as well????
mx83toy
Re: "Piggy back sensor" for 1JZ speedo Wed, 30 June 2004 15:27 Go to previous messageGo to next message
anywayz the ppl id speak to are
grant aka sixworks
jim aka sidshow his number is 0415904947
woofa347
Whyalla
Re: "Piggy back sensor" for 1JZ speedo Wed, 30 June 2004 23:47 Go to previous messageGo to next message
Yeh Im hoping it is the same, but I havnt had a chance to have a look yet, my car is at an exhaust workshop having alu piping made up for the intercooler and air intake.
Which way would be better, getting the speedo sensor or if the MX73 dash sensor is the same as the MX83 one, just hook that upto the ECU.
woofa347
Whyalla
Re: "Piggy back sensor" for 1JZ speedo Thu, 01 July 2004 09:24 Go to previous messageGo to next message
I have ordered a speed sensor through Grant at sixworks, and he said you use that to hook up the 1JZ to MX73 dash, and the speed signal to the ECU comes from the speedo
itself and can be found on any schematic for the MX73
mx83toy
Re: "Piggy back sensor" for 1JZ speedo Thu, 01 July 2004 12:26 Go to previous messageGo to next message
yep thought so Razz
i plugged in the standard cressi one
Grant
Newcastle, NSW, Australia
Re: "Piggy back sensor" for 1JZ speedo Sun, 04 July 2004 00:09 Go to previous messageGo to next message
Ahh, just to clarify something here; I only supply Tacho Boosters and not speed sensors. For 1J Cressida conversions you only ned to swap out the speed sensor and fit the 7M speedo drive to get the speedo working. The speed signal can then be connected directly to the 1J ecu from wire SP1 that comes from the Cressida speedo.
While I can get speed signal generators that plug in-line to the speedo cable, they are only required for conversions on early model cars (like Celicas) that don't already have a speed signal wire from the speedo. Even then you can get around the problem by using a speed sensor and pick-up from a non-ABS 7M box.
woofa347
Whyalla
Re: "Piggy back sensor" for 1JZ speedo Mon, 05 July 2004 08:02 Go to previous message
Thanks for the clarification, I didnt know how to explain it Razz
Previous Topic:MX73 Power Steering mount
Next Topic:mega urgent
Current Time: Tue Oct 20 22:53:45 UTC 2026
Total time taken to generate the page: 0.00636887550354 seconds
