Toymods » Tech & Conversions » clutch for 18RG
edwin
Victoria, near Frankston
clutch for 18RG Mon, 21 June 2004 09:59 Go to next message
What would be a good clutch for an 18RG (and W50)? Ive done some searching and reading and found that the std (18RC) clutch would probably not be good enough. Ive found contradicting info on RPM clutches. Any suggestions?
Can I just pick a "heavy duty RPM clutch" up at Repco and expect it to fit?
Thanks.
Re: clutch for 18RG Mon, 21 June 2004 23:02 Go to previous messageGo to next message
Talk to a clutch specialist and get them to build a clutch to your requirements. There probably isn't much you can buy "off the shelf" to do what you want.
ta22gt
Re: clutch for 18RG Tue, 22 June 2004 00:59 Go to previous messageGo to next message
Edwin i have just had my clutch recod by steve at direct clutch in bris. they specialise in race set ups etc my clutch is a 5 puck sprung centre button clutch give him a call and they are happy to freight anywhere in oz good luck .
NEV
edwin
Re: clutch for 18RG Tue, 22 June 2004 08:51 Go to previous messageGo to next message
Thanks guys, I'll contact Direct Clutch tomorrow and I will try to find a clutch place closer to home as well, cos I'll need to have my flywheel machined too.
How much weight can I take off and still have a good daily driver?
people100
Rocklea qld
Re: clutch for 18RG Tue, 22 June 2004 09:39 Go to previous messageGo to next message
how much power you got. Standard 18rc clutch should handle 150 hp easily.
edwin
Re: clutch for 18RG Tue, 22 June 2004 09:51 Go to previous messageGo to next message
I'm hoping for 150 hp, just a std. 18RG with 40mm Solexes and extractors. Nothing spectacular.
people100
Rocklea qld
Re: clutch for 18RG Wed, 23 June 2004 10:40 Go to previous messageGo to next message
dont the rg's have 44 mm solexs..you will not alot more work then that to get 150hp.just keep your standard clutch.
Re: clutch for 18RG Wed, 23 June 2004 10:48 Go to previous messageGo to next message
my turbo 18R has a std clutch but a pressure plate with a lot more clamping pressure.
seems to have worked so far (can't say the same about other motor parts).
the pressure plate came from direct clutch i think - i got it thru budget auto parts @ oxley.
edwin
Re: clutch for 18RG Wed, 23 June 2004 12:00 Go to previous messageGo to next message
people100 wrote on Wed, 23 June 2004 20:40
AFAIK the 18RG originally came with 40mm solexes. According to the Toysport site you only need 44's when it is bored.
edwin
Re: clutch for 18RG Thu, 24 June 2004 04:40 Go to previous messageGo to next message
I want a new clutch anyway, as I am replacing engine and box. Might as well get it done, so I don't have to take everyting apart again when the clutch needs replacement.
So I have been asking around and Repco told me a std clutch for the RA23 is $166 (PBR) and a heavy duty one would be $195 (RPM). I also rang a clutch&brake place and they quoted $230 for a Exedy Daikon, which according to him has 58% more pressure than the std RA23 clutch and it should fit in without mods.
I am tempted to go for the last option, as the difference is only $64. Does anyone have experience with Exedy Daikon? Are they any good? Does the price sound reasonable?
SRacin
Christchurch, New Zealand
Re: clutch for 18RG Thu, 24 June 2004 07:23 Go to previous message
I have the h/d excedy diakin. Its in a 18rgeu power rt40, and with the ra63 w55 slave and standard master it feels good, not to heavy either. Was lucky with the clutch as it was basically brand new and came in the wreck I brought for $250 so cant complain. Have only had a little drive belt i like it and no sign of slippage (stock 18rgeu), but it took a bit of punishment (compulsary stage 1project completion burnouts.... Rolling Eyes ) with no ill effects.
Id say go tyhe h/d
Logan
Previous Topic:JDM early model blinker same as AUS spec?
Next Topic:Pics of front mount piping on AE82 / 92 etc
Current Time: Sun Oct 25 20:59:11 UTC 2026
Total time taken to generate the page: 0.0045859813690186 seconds
