Toymods » Tech & Conversions » What are Component Speakers?
crayz legz
What are Component Speakers? Mon, 21 June 2004 22:52 Go to next message
Hi i was just wondering if someone could tell me what component speakers are?
Maurice c
Re: What are Component Speakers? Mon, 21 June 2004 23:42 Go to previous messageGo to next message
Component speakers are speakers that produce their sound from separate locations. Rather then having just one speaker with a tweeter in it, you might have a tweeter mounted in the dash and a mid range speaker in the door card. Both of them run off the same feed though. Somebody might be able to give you a better explanation though
crayz legz
Re: What are Component Speakers? Tue, 22 June 2004 08:49 Go to previous messageGo to next message
thanks, and which one produces better quality? normal splits or component speakers?
V8_MA61
Re: What are Component Speakers? Tue, 22 June 2004 09:30 Go to previous messageGo to next message
component speakers are exactly what the first word is: components.
Each frequency has its own seperate component. These can sound crap or really good depending on how you install them.
For example,
If you have the tweeter and woofer in the door next to each other it might sound no better than a normal coaxial speaker (woofert with tweeter internally mounted) however, if you were to stick the woofer in the door and the tweeter in the dash/ high in the door, it might sound great...its all relevant to installation!
Component speakers do no suit rear shelf applications...
Cyber-punk
Brisbane, QLD
Re: What are Component Speakers? Tue, 22 June 2004 09:47 Go to previous messageGo to next message
i think V8_MA61 means frequency range...it would be rather cramped if you had a speaker for each individual frequency
...dont mind me
i'm just being pedantic tonight
V8_MA61
Re: What are Component Speakers? Tue, 22 June 2004 10:09 Go to previous messageGo to next message
component speakers normally come with a crossover doofus Razz well..good ones anyway!
Cyber-punk
Brisbane, QLD
Re: What are Component Speakers? Tue, 22 June 2004 10:15 Go to previous messageGo to next message
*sigh*
the last person to call me doofus was a hot brunette....you just HAD to taint that word for me Sad
V8_MA61
Re: What are Component Speakers? Tue, 22 June 2004 10:41 Go to previous messageGo to next message
sorry man Heart didnt mean it
digitalpho3nix
St James, Perth
Re: What are Component Speakers? Wed, 23 June 2004 12:21 Go to previous messageGo to next message
Component speakers are made up of 3 parts, a tweeter for high frequencies (approx 1kHz thru to 20kHz), a midrange woofer (for the middle range of frequencies: ~90 Hz thru to 1 kHz). The woofer or subwoofer handle the lower frequencies. A Crossover is used so that high frequency sounds are sent to the tweeter, and other sounds sent to the midrange (A crossover usually consists of Hi Pass and a Low Pass filters).
As to which sound better, the components will sound better IF they are installed correctly. As a general rule, tweeters should be aimed as close to the listening position as possible (as short wavelength noise is easily absorbed by objects), midrange must be pointed in your general direction, and for the subwoofer, the sound is almost non-directional so it doesn't matter.
Hope this answers your question. Smile
V8_MA61
Re: What are Component Speakers? Wed, 23 June 2004 12:28 Go to previous messageGo to next message
mids are generally used from about 200-700hz Wink
Anything below 120hz is pretty much non directional
Edit: generally speaking, cars dont have midrange speakers.
[Updated on: Wed, 23 June 2004 12:30]
crayz legz
Re: What are Component Speakers? Thu, 24 June 2004 04:56 Go to previous messageGo to next message
thanks it does. would you connect the component speakers to an amplifier still? and if i bought all my stereo stuff from japan (head unit, amp, speakers, subs,etc.) would it work in my car here?
Re: What are Component Speakers? Thu, 24 June 2004 05:00 Go to previous messageGo to next message
crayz legz wrote on Thu, 24 June 2004 12:56
I would, because it's pretty much guaranteed to sound better providing you don't have a crap amp.
The tuner in the radio wouldn't work properly, there is some workaround though. It's cos we use a different frequency band. The rest of it will work fine.
crayz legz
Re: What are Component Speakers? Thu, 24 June 2004 07:19 Go to previous messageGo to next message
ok kool, is there any way to fix the frequency band though so tha radio and tuner does work?
Major Clod
Re: What are Component Speakers? Thu, 24 June 2004 11:37 Go to previous messageGo to next message
Components tend to be better quality speakers because they are the type of speakers that are focussed in higher end audio. You can definately get some great sounding co-axials, but the fact that most companies focus on components means they will be hard to find.
Components are best installed as far forward as possible, and as a general rule it is good to have the tweeters and mid bass aimed at the opposite sides headrest, but its really up to a bit of experimentation on what sounds best for you.
You will plug your components up to an amp. The amp will send power to the crossover, which splits the signal into two different frequency ranges. High for the tweeters, and low for the mid bass.
As for your radio, Jaycar sells an FM converter that deals with this issue. Apparently jap AM is the same so no worries there.
http://www1.jaycar.com.au/productView.asp?ID=AR310 0&CATID=24&keywords=&SPECIAL=&form =CAT&ProdCodeOnly=&Keyword1=&Keyword2= &pageNumber=&priceMin=&priceMax=&S UBCATID=526
My Clarion from the US allowed me to change "regions" so that it could pick up FM and AM perfectly over here.
crayz legz
Re: What are Component Speakers? Thu, 24 June 2004 11:41 Go to previous message
thanks heaps
Previous Topic:Coolant temp sensor in 4AFE - 2 or 1?
Next Topic:Doesany one know if it is possible to convert 93 mazda rx7
Current Time: Thu Nov 19 08:21:33 UTC 2026
Total time taken to generate the page: 0.0068700313568115 seconds
