Toymods » Tech & Conversions » 2r - 18r conversion
lilcrash
ipswich queensland
2r - 18r conversion Tue, 22 June 2004 08:38 Go to next message
i am thinking about putin an 18r into my hilux instead of the original 2r, and i was just wondering if ne one knows if it is possible and wat needs to be done to put it in.
its the colomn shift manual, in not sure about the clutch, and tailshaft situation, are the splines the same or diffrent???
thanx for your help in advance
lilcrash
ipswich queensland
Re: 2r - 18r conversion Wed, 23 June 2004 04:23 Go to previous messageGo to next message
can anyone help me please
SRacin
Christchurch, New Zealand
Re: 2r - 18r conversion Wed, 23 June 2004 05:26 Go to previous messageGo to next message
Are you sure the hilux has a 2r? or is it a 12 R, either way look at the thread on the rt40, where i replaced the 2r with an 18rg, however, being a hilux im really not qualified to answer, but there may be possibilities of a x-member swap. not sure...
lilcrash
ipswich queensland
Re: 2r - 18r conversion Wed, 23 June 2004 08:13 Go to previous messageGo to next message
thanx il have a look
yer its a 2r, its a 72 hilux
Re: 2r - 18r conversion Wed, 23 June 2004 10:40 Go to previous messageGo to next message
are you doing motor+ box or just motor? as the both engines 'should' bolt to the same bellhousing (being 'R' series engines)?
and why not dump the column shift and go 5sp W50 (that would come with 18R 5ps fro ma celica) and cut a hole in the floor?
You're probably up for different tailshaft (length) if you go from 4sp to 5sp?
cheers,
lilcrash
ipswich queensland
Re: 2r - 18r conversion Wed, 23 June 2004 10:44 Go to previous messageGo to next message
its got a bench seat so i cant put a on the floor box in
and i cant get my hands on a good box
SRacin
Re: 2r - 18r conversion Wed, 23 June 2004 10:55 Go to previous messageGo to next message
yea, but toyota's really are big boys lego..I did the 2r + 4spd to 18rgeu + w55 and the tailshaft from a slightly later model corona fitted perfectly Smile...
Also the 12R will bolt to the standard box, however the 18r will not.
Logan
lilcrash
ipswich queensland
Re: 2r - 18r conversion Wed, 23 June 2004 11:01 Go to previous message
ok thanx
il have to use one of the corona boxes then and put in 2 bucket seats
Previous Topic:help with Ae-86 flasher can problem
Next Topic:manifold price for st162
Current Time: Sun Nov 1 21:55:05 UTC 2026
Total time taken to generate the page: 0.005620002746582 seconds
