Toymods » Tech & Conversions » Coolant temp sensor in 4AFE - 2 or 1?
HighRolla
Coolant temp sensor in 4AFE - 2 or 1? Tue, 22 June 2004 13:36 Go to next message
Just wondering in a 4AFE or 4AGE is there both a temp sensor/sender
for the temp gauge and another sensor for the ECU to adjust fuel injection duration etc or do they both run off the one sensor. In the Haynes manual it speaks of the gauge sending unit located in cylinder head but doesn't mention the one that gives signal to ECU.
I also realise there is a switch for the thermo fan that is seperate to all this.
Thanks,
Ben
Re: Coolant temp sensor in 4AFE - 2 or 1? Tue, 22 June 2004 16:31 Go to previous messageGo to next message
from blue book, looks like there is a seperate temp sender for the ECU. this sensor looks like it is in the block (on the diagram here anyways)
as opposed to the normal water temp sensor which in near thermostat in most cars...
HighRolla
Re: Coolant temp sensor in 4AFE - 2 or 1? Wed, 23 June 2004 11:40 Go to previous messageGo to next message
Thanks Stewart - just checked out the 4age book now (good idea).
Wuestion for someone out there:
Can anybody report if the below is the gauge sending unit or is that seperate again to this? i.e does this only send to ECU and there is seperate one for the gauge?
http://toymods.org.au/Repository/TechDocs/4age_book/efi/fi_96.jpg
I found the temp switch for the fan but I think that is seperate all together
Re: Coolant temp sensor in 4AFE - 2 or 1? Wed, 23 June 2004 13:54 Go to previous messageGo to next message
Yes, the gauge one is completely separate, and is the same as the 4AFC. I am STILL baffled by a small wiring issue that's causing me trouble with an AE92 that was, er, 'converted' from 4AFC to 4AFE, the temp gauge will NOT work properly! ACK!
HighRolla
Re: Coolant temp sensor in 4AFE - 2 or 1? Thu, 24 June 2004 11:56 Go to previous message
thnaks for reply mrshin
That's no good about your wiring prob..how does it run besides that..was the conversion a hassle?
Previous Topic:4agte Oil/Water Lines?
Next Topic:What are Component Speakers?
Current Time: Thu Nov 19 07:00:28 UTC 2026
Total time taken to generate the page: 0.0052540302276611 seconds
