Toymods » Tech & Conversions » whart would u call lumpy cams {18RG}
Mr DOHC
whart would u call lumpy cams {18RG} Wed, 23 June 2004 08:25 Go to next message
i have just gotten my cam sheet, what would u call lumpy, duration and lift
also, a few weeks ago, someone posted 18RG cam lift figures, i cant find them, help!!
[Updated on: Wed, 23 June 2004 09:00]
M.J.H
Re: whart would u call lumpy cams Wed, 23 June 2004 08:44 Go to previous messageGo to next message
I think some 286 cams with 9 or 10mm lift should be enough for these sort of motors.
At least that is what i was going to go for in mine but i might wait to see what you use and what results you get from them. Very Happy
Curious as to what the sheet says is avalible.
Mr DOHC
Re: whart would u call lumpy cams Wed, 23 June 2004 08:58 Go to previous messageGo to next message
well as far as i can remember the 18RG has about 10.5mm std
details of my cams
Surecam grind number B-12Z-6
lift: .465"{11.8mm} ex: .465 {.455 net}
max lift is at 102deg for intake and 110deg for exhaust {what does that mean Confused }
duration at .050" 233deg for ex and in
duration at seat: 282 for both
lobe separation 106 deg
timing:
InO: 14.5d BTDC
InC: 38.5d ABDC
ExO: 46.5d BBDC
ExC: 6.5d ATDC
power range 3000-6500, "fast road"
it says down the bottom
Quote:
install cam with an intake bucket lift of .125" at TDC and an exhaust bucket lift of .081" at TDC
what the hell does that mean
M.J.H
Re: whart would u call lumpy cams {18RG} Wed, 23 June 2004 09:34 Go to previous messageGo to next message
Yeah i think i mine where 10mm lift but the lobe is very much throw it open then shut.I was after a longer duration to hold the valve open longer not so much more lift.
As for your cams and installing them,with the motor at top dead centre then the inlet cam should have the bucket down .125" and the exhaust should be .081" lift.If they aren't then they are timed wrong and need to be rectified.
Just need a degree wheel and dial guage to set them up properly and all should be sweet.
Are you just fitting some cams or doing the whole motor as well?Cause if you are doing the whole motor then set the cams up while the motor is in the engine stand with the head just bolted on and no head gasket,also put some play dough on the piston,to make sure the valves will not kiss the pistons.Once you have them right then you can put it all together with the gasket giving you that little bit of extra clearance.
If not the winding over by hand very gently by hand should allow you to feel if they want to hit or not.
Does anyone have the open and close specs for the std cams as i would be interested to compare.
Mr DOHC
Re: whart would u call lumpy cams {18RG} Wed, 23 June 2004 11:27 Go to previous messageGo to next message
so i dont set them up as std {both cut outs pointing straight up}??
how would i know how much lift there is at TDC
V8_MA61
Re: whart would u call lumpy cams {18RG} Wed, 23 June 2004 11:29 Go to previous messageGo to next message
mine is 596' lift, that enough? Rolling Eyes
Edit: oops you were being specific to 18rgs Razz
[Updated on: Wed, 23 June 2004 11:39]
CelicaRA45
nth ringwood, Victoria
Re: whart would u call lumpy cams {18RG} Wed, 23 June 2004 12:43 Go to previous messageGo to next message
my cams are 535 thou lift and are 296 duration and at 50 thou are 260 duration and are 100 crank degress at tdc
Re: whart would u call lumpy cams {18RG} Wed, 23 June 2004 13:23 Go to previous messageGo to next message
your cam/s is abotut he same as my cam.. but mine is 4K Wink
with injection, idle should be ok.. my cam make peak torque around 4500, and there's not much below 3500.. EFI will help me tho.
what MJH said Wink
if you need a dial gauge, i have a crap one...
start by putting cams in at stock positions, but you may find you need to alter them a little....
start stock, measure lift at TDC and see if you need to move them around...
M.J.H
Re: whart would u call lumpy cams {18RG} Wed, 23 June 2004 18:57 Go to previous messageGo to next message
Mr DOHC wrote on Wed, 23 June 2004 21:27
The dial guage will tell you what lift there is.
Set it up so it works on the bucket and with the valve closed set it to zero then wind the motor/cam over till TDC and see what lift you have.Adjust from there if needed till you get the right numbers.Degree wheel will tell you what the crank is doing so you can back it up with those settings as well.
Or what Stewart said.
Hope that helps.
Martin
CelicaRA45
Re: whart would u call lumpy cams {18RG} Thu, 24 June 2004 06:39 Go to previous messageGo to next message
also in cams as a rule dont worry about if it is say 320 duration cam and has heaps of lift go by the 50 thou mark that will tell how hot the cam is and also how hard it is on the valve train you will need to change the valve springs std lift for the rg are 10.5 mm any way as i was saying 320 duration but at 50 thou only 266at 50
or 296 dur and at 50 thou 262 at 50 the 2nd 1 is harder on the valve train than the 1st 1 so when oredring a cam profile always look at the 50 thou mark .
on the 18rg motor something btw 250 and 260 tops and also for advertised no more than 290 degress ,if using the std valve springs get them tested to see if they can handle the extra lift
Mr DOHC
Re: whart would u call lumpy cams {18RG} Thu, 24 June 2004 09:48 Go to previous message
duhm didnt een think to set it up on the buckets Rolling Eyes
mine are 233 at 50 thou, and i'm getting new everything, new springs, Ferrea stainless valves, new guides and seats ect ect
Previous Topic:1UZ Crown Majesta wiring diagram
Next Topic:Fuel pump replacement option for 162 with 3sgte
Current Time: Thu Nov 19 09:36:20 UTC 2026
Total time taken to generate the page: 0.0062830448150635 seconds
