Toymods » Tech & Conversions » Problem starting my st162
doobs
Geelong.Vic.AU
Problem starting my st162 Thu, 24 June 2004 06:16 Go to next message
Ey all,
I have a problem trying to start my celica, once in ~40 starts the car just wont go. All I hear is a click but no noise from the startermotor or engine.
Its seems if I wiggle the + terminal, the car will start. I have cleaned all the terminals but it has made no difference.
I read something about a relay going to the startermotor but I havent seen any wireing diagrams or pics.
If any one can offer me some suggestions it be great.
Aust162
Melb, Victoria
Re: Problem starting my st162 Thu, 24 June 2004 09:12 Go to previous messageGo to next message
maybe the solinoid on ur starter motor is dying?next time it happens, try tapping the starter motor. (if u can reach them, sorry not sure Sad )
i know my friend had real simular probs with his falcon and thats what he use to do to start his car.lol
ST162GT-R
QLD, Gold Coast
Re: Problem starting my st162 Thu, 24 June 2004 09:25 Go to previous messageGo to next message
Yeah i had the same problem, on cold starts, i got NRMA to fit in starter relay kit, and my cars started everytime, although i think my starter motor is about to give, but yeah starter relay seem to do the trick, about 89 bucks.
sik sx
Sunshine Coast
Re: Problem starting my st162 Thu, 24 June 2004 12:01 Go to previous messageGo to next message
flat battery.dodgy alternator,dodgy starter motor, something wrong in the the ignition
thers some possibilties
SillyCar88
Elwood, Melb
Re: Problem starting my st162 Thu, 24 June 2004 14:58 Go to previous messageGo to next message
KICK IT!!! Or maybe put some fuel in it, nah just kidding, it's most likely your starter, because normaly you should hear a few clicks if it isn't. 2c
matt86sx
Gold Coast, QLD
Re: Problem starting my st162 Thu, 24 June 2004 23:57 Go to previous messageGo to next message
The starter problem is a well known issue with ST162's, especially now that they are all approaching 20 years old. It seems to be more a case of when it will happen, not if!
Here's a couple of threads in the 4th gen forum of celica.net that may help you:
http://celica.net/cgi-bin/ultimatebb.cgi?ubb=get_t opic;f=32;t=000569
http://celica.net/cgi-bin/ultimatebb.cgi?ubb=get_t opic;f=32;t=002493#000000
Do a search for "starter" in the 4th generation forum at celica.net and you'll find heaps of other posts about it too, since it's becoming such a common problem.
Hope these help!
-Matt
doobs
Geelong.Vic.AU
Re: Problem starting my st162 Thu, 24 June 2004 23:58 Go to previous messageGo to next message
Hmm something new happend tonight, now when my car starts, just after it kicks over the starter gives a clicking noise, I think it may be on the way out. I will have to see about getting a starter relay. Ill get the mechanic to have a look today.
Maurice c
Re: Problem starting my st162 Fri, 25 June 2004 02:40 Go to previous messageGo to next message
The starter is probly sticking on. Better fix this before your looking for another flywheel. Get a recon starter.
doobs
Geelong.Vic.AU
Re: Problem starting my st162 Fri, 25 June 2004 03:25 Go to previous messageGo to next message
Ok
I may have fixed the problem (touch wood Razz)
As i found that I already have a relay installed (zip tied to the + cable), I decided to disconnect it and check all the connections. As i removed the tape from it, one of the connection fell right off. I cleaned all the contacts and put them on more securly. I taped and ziptied it together and it hasent happend since.
This would explan why shaking the + battery termanal would fix things but then after a drive it would not start again.
Also the starter is sounding normal again.
I hope its fixed.
Thanx for the help everyone.
Ice_majik
Re: Problem starting my st162 Fri, 25 June 2004 09:28 Go to previous messageGo to next message
I think it must be the motor ,especially if its a turbo engine... so give it to me...LOL Razz
Seriously, yep I say starter too.
patrick
Re: Problem starting my st162 Sat, 26 June 2004 03:25 Go to previous messageGo to next message
I think I have the same problem. This morning I tried to start my ST162 and all it did was click over and over, and the lights/stereo flashed on and off and i heard nothing coming from the starter motor etc.
I'm reading some pretty useful info on that celica.net site, but I'm having trouble understanding the diagrams for the wires etc. I'm not sure if I'm doing the right thing by doing this either...
Confused
doobs
Geelong.Vic.AU
Re: Problem starting my st162 Sat, 26 June 2004 08:50 Go to previous messageGo to next message
first thing to do is check to see if you have a relay, if you do, then the wires may be loose, or the fuse maybe blown. If you dont, then you will have to get one.
The diagram is stupid and very hard to follow, look at what wire they say goes to each pin, its easy to figgure out then.
*I HIGHLY reccomend you solder the terminals on the relay, saves you from haveing the problems i did*
Heres a description right from the celica.net forum, posted by 88BlackGT-S
"This fix was posted by me over a year ago when I was just getting into fixin' my car, so here goes again. If you can wire a car stereo then you should have no problem with the starter relay fix.
Buy a 12V auto relay, wire the terminals as follows(only 4 wires to hookup):
87 - +12V (fuse this wire at battery with 30 amp)
85 - Ground (battery or chassis your choice)
86 - starter solenoid wire (ignition side)
30 - starter solenoid wire (starter side)
***The starter solenoid wire is the smaller wire coming off the starter. Black w/yellow stripe I believe, there is a connector which you will have to cutt off in order to splice in the relay. While you are at it remove starter and check the big wire for corrosion, if so replace or clean up. Starter is located underneath the exhaust manifold. Pain in a** to remove, but worth doing at least once.
You can use solderless terminals or you can solder all the connections for even better reliability, best to use 12 to 14 gauge wire for the connections. Wrap everything with electrical tape to keep out water and dirt."
[Updated on: Sat, 26 June 2004 08:57]
patrick
Re: Problem starting my st162 Sat, 26 June 2004 09:07 Go to previous messageGo to next message
Thanks doobs for the info. I'm getting a service real soon so my mechanic'll have a look at it (I'll still check if I have a relay and do what I can etc.)
Cheers. Smile
SillyCar88
Elwood, Melb
Re: Problem starting my st162 Sat, 26 June 2004 13:23 Go to previous messageGo to next message
Ice_majik wrote on Fri, 25 June 2004 19:28
WTF?
doobs
Geelong.Vic.AU
Re: Problem starting my st162 Sun, 27 June 2004 11:32 Go to previous message
patrick wrote on Sat, 26 June 2004 19:07
Cheers. Smile
Ahh thats cool, but if its a loose connection on ya relay, dont let the mechanic charge you $xxx to fix it, do it ya self and save a few $s.
Previous Topic:2T Engine Manual on CD
Next Topic:For those R32/300ZX brake on AE86/RAxx Qs?
Current Time: Fri Nov 20 00:50:08 UTC 2026
Total time taken to generate the page: 0.004925012588501 seconds
