Toymods » Tech & Conversions » Oversized 4AC Carbys
WHITCHY
Castle Hill
Oversized 4AC Carbys Thu, 24 June 2004 07:21 Go to next message
Hey,
I need a new carby for my 4AC, and one of my mates said some stuff about getting an oversized carby so it will suck more fuel down and increase performance.
Is he talking shit, or are these things available(if so where from),and do they work as he has told me?
I realise if they are around that it wont make a big difference in performance, but some is better than none!
Thanks to anyone that can help me out with this.
-Whitchy-
nicked
Re: Oversized 4AC Carbys Thu, 24 June 2004 07:30 Go to previous messageGo to next message
search "4ac weber" will tell you stuff.
Re: Oversized 4AC Carbys Thu, 24 June 2004 07:59 Go to previous messageGo to next message
WHITCHY wrote on Thu, 24 June 2004 17:21
Hey,
-Whitchy-
to be blunt he's talking shit
if the carb is already supplying enough air, with the correct amount of fuel... it will make no difference except possibly worse everywhere except WOT..
if the carby is undersized, then a carby with larger throats can help allow the engine to suck in more air IF, and only IF, the engine needs more air..
if the carb is not the restriction......
what you might want to do is look to some of the early euro cars with downdraft Webers... early 70's FIAT's come to mind..
aiui, webers have better atomisation than Aisan's, so it may help a bit... don't go overboard on size tho...
another option might be the falcon 32/36.....
but as always, if you don't know why you need it, you probably don't.
ps, whatever carb you get will have to be re-jetted. this can be an expensive exercise if you don't know what you are doing... at $5-10 each, the cost of jest quickly adds up..
Re: Oversized 4AC Carbys Thu, 24 June 2004 08:12 Go to previous messageGo to next message
remove the EGR on your 4ac and all the vacuum shite. This should help more than an oversized carby.
Ice_majik
Re: Oversized 4AC Carbys Fri, 25 June 2004 09:34 Go to previous messageGo to next message
The Falcon weber is a 34ADM and way to big ...dont even consider that one its a 6cyl application.
A 32/36 weber off a ford escort/cortina downdraft is the best conversion without overdoing it ... should set you back around $550 for a reco unit fitted. Cool
AE86slut
Baulko Hillo
Re: Oversized 4AC Carbys Fri, 25 June 2004 09:39 Go to previous messageGo to next message
Beat me to it.... I was going to suggest an Esky/Corty Weber. Too bad... I had about 4 of them sitting 'round and chucked 'em!
Save up and put a 4AGE in it.
Super Jamie
On Probation
North East NSW
Re: Oversized 4AC Carbys Thu, 01 July 2004 01:37 Go to previous message
Ice_majik wrote on Fri, 25 June 2004 19:34
actually on a stock 4ac these would both probably go like shit at low rpm. they're big carbs designed for >2L engines, and won't have the low down throttle response of the original type carb, it will take a few revs (2500?) before you get decent power. that being said, they'll definately improve power up high, if you get them tuned and jetted properly they won't be too bad down low either
and yes, you can use a 34ADM on a 4ac, hell one of the guys on oldcorollas has one on a cammed 4K and it cracks, bit doughy down low but anything bigger on a 1300 is going to be like that, but i digress
Previous Topic:2TG starting problems
Next Topic:help me rebuild my 5k engine!!
Current Time: Fri Oct 23 02:58:38 UTC 2026
Total time taken to generate the page: 0.011094093322754 seconds
