Toymods » Tech & Conversions » 4agte Oil/Water Lines?
adavy84
Perth, WA
4agte Oil/Water Lines? Thu, 24 June 2004 08:00 Go to next message
Hey where do u connect the oil and water lines for the Turbo?
Engine is Small Port Map 4agze.
also what shop in perth will sell the lines im after?
NVD05X
parra
Re: 4agte Oil/Water Lines? Thu, 24 June 2004 08:45 Go to previous messageGo to next message
if you dont know i dont think you should be doing it yourself...
adavy84
Perth, WA
Re: 4agte Oil/Water Lines? Thu, 24 June 2004 08:48 Go to previous messageGo to next message
i do mean to the engine.
45aken
NSW.south coast.Drifting
Re: 4agte Oil/Water Lines? Thu, 24 June 2004 09:04 Go to previous messageGo to next message
well if you know then it shouldn't be that hard.
oil in must be pressurised (eg after the oil pump)
oil out just drains to the sump
water- just make it a part of the water circulation, but put the inlet(on the turbo) after the radiator, and the outlet before the radiator. so you get cooler water to the turbo.
just have a look at the motor and look for parts on it that will allow you to achieve this.
NVD05X
parra
Re: 4agte Oil/Water Lines? Thu, 24 June 2004 09:07 Go to previous messageGo to next message
who said it was hard?
my oil feed comes from the oil pressure switch threaded hole...
the water is inline with the heater hoses...
45aken
Re: 4agte Oil/Water Lines? Thu, 24 June 2004 09:42 Go to previous messageGo to next message
i meant it like
"shouldnt be hard to work out where to put them"
directed at adavy84
ae95
Re: 4agte Oil/Water Lines? Thu, 24 June 2004 09:44 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=34651&rid=2738&S=f26c6de9e00db431ec90d29 bf6dfb145&pl_view=&start=0#msg_305424
good luck mate
NVD05X
parra
Re: 4agte Oil/Water Lines? Thu, 24 June 2004 10:18 Go to previous messageGo to next message
ahh now i get it!!
i was like wtf?!!!!
its all good
adavy84
Perth, WA
Re: 4agte Oil/Water Lines? Thu, 24 June 2004 12:38 Go to previous messageGo to next message
Thanks all!
feral4mr2
Bundaberg, Qld.
Re: 4agte Oil/Water Lines? Thu, 24 June 2004 13:18 Go to previous messageGo to next message
i used a braided line with a steel fitting from the oil pressure sender hole, which goes to a remote mounted metal tee peice that has the oil pressure sender and a braided turbo feed line on it going to the turbo.
the reason i have remote mounted the oil pressure sender and turbo feed tee peice is a lot of people have had their tee peice break (including me) at the block from too much weight on it with viabration etc.
i have tee'd my heater lines to run the coolant through the turbo. this is how HKS did it originaly.
TE72_Turbo
Re: 4agte Oil/Water Lines? Thu, 24 June 2004 13:38 Go to previous message
Too true. The brass fittings are pretty ordinary quality, and really dont go well with the weight of an electric oil pressure sender hanging off the end. Its a real bitch to get the broken piece out of the thread in the block too!
Another idea for the water is to feed from the block. Near the front of the block on the exhuast side there is a brass coolant drainage tap that can be removed & replaced with a hose fitting, then have the other hose from the turbo going back to the top radiator tank (or whichever is the hot side of the radiator if your tanks are on either side)
Phil
Previous Topic:need help!!!
Next Topic:Coolant temp sensor in 4AFE - 2 or 1?
Current Time: Thu Nov 19 06:19:30 UTC 2026
Total time taken to generate the page: 0.0055270195007324 seconds
