Toymods » Tech & Conversions » need help!!!
Pa2jK
need help!!! Thu, 24 June 2004 08:17 Go to next message
Hi guys
Was driving home just now and suddenly the battery charge sign came on. what could be wrong with it? Crying or Very Sad after a while noticed that idling was at 1300rpm instead of 900rpm normally.
Its a ae86 with a 4ac in it. thinking it might be a problem with the alternator. Any help will be much appreciated.
Pa2jK
Re: need help!!! Thu, 24 June 2004 11:49 Go to previous messageGo to next message
bump!!!! anyone?? pls???
Techie
Re: need help!!! Thu, 24 June 2004 13:35 Go to previous messageGo to next message
Stick a volt meter ground and the back of the alternator. Sometimes if its not putting out enough voltage/current it can affect the way the motor runs.
Re: need help!!! Thu, 24 June 2004 13:40 Go to previous messageGo to next message
your alternator is probably not charging. since it's not charging, it's not slowing the motor down the way it usually does.
probably just the brushes, possible something else (field diodes, regulator, stator/rotor)
pull it out and have a look...
Techie
Re: need help!!! Thu, 24 June 2004 13:44 Go to previous message
well there is that too Razz
I must be too lazy tonight to give any sort of technical answer
[Updated on: Thu, 24 June 2004 13:45]
Previous Topic:Suspension Height Problems
Next Topic:4agte Oil/Water Lines?
Current Time: Thu Nov 19 07:00:30 UTC 2026
Total time taken to generate the page: 0.0058271884918213 seconds
