Classifieds » Parts Wanted » Edit: 2t block needed
The Untouchable
Ballarat
icon6.gif  Edit: 2t block needed Thu, 24 June 2004 09:28 Go to next message
Hmm, i dunno whether u've read my saga. but yeah, im after a block, doesnt have to have anything on it cept the 3t block :s
and one piston :s :s
worth an ask
[Updated on: Sat, 10 July 2004 08:39]
fergo308
Eastern Sydney
Re: Cheap 3t block and one 3t piston needed :s Fri, 25 June 2004 08:22 Go to previous messageGo to next message
I don't know if this is of any use to you or not,but I have a 2t block which has had the sides ground out some to suit 3t rods and crank.
I also have a spare 2tg head,a timing case cover,oil pump,and a few other bits.
email me at fergo308@hotmail.com if you're interested,and we'll see what we can do.
Justin...
[Updated on: Fri, 25 June 2004 08:23]
The Untouchable
Ballarat
Re: Cheap 3t block and one 3t piston needed :s Fri, 25 June 2004 08:46 Go to previous messageGo to next message
yeah i actually meant to write i need a 2t block. why has it been ground? i was under the impression you didnt need to touch the block in order to make 3t cranks and rods fit?
approx how much u want for it?
fergo308
Eastern Sydney
Re: Cheap 3t block and one 3t piston needed :s Fri, 25 June 2004 09:00 Go to previous messageGo to next message
the small amount of reading I've done on the subject over the last couple of months had me believing that you need to grind the block some.
regardless,this block had a couple of mm taken out of the side for rod clearance. whether it needed it or not,I can't say,as I got it disassembled.
if you organise to get it picked up,it's yours for $50.
I'm in Sydney,Bondi area.
let me know if this suits you.
Justin...
0418 663628
The Untouchable
Ballarat
Re: Cheap 3t block and one 3t piston needed :s Fri, 25 June 2004 10:20 Go to previous messageGo to next message
oh shit...im in victoria bro Sad
fergo308
Eastern Sydney
Re: Cheap 3t block and one 3t piston needed :s Fri, 25 June 2004 10:26 Go to previous messageGo to next message
a little far to pop over and grab it,but not impossible to organise.
depends how badly you need a block I guess.
Justin...
jesseT18
Castle Hill, Sydney
Re: Cheap 3t block and one 3t piston needed :s Fri, 25 June 2004 22:57 Go to previous messageGo to next message
i've got the piston your after
[Updated on: Fri, 25 June 2004 23:06]
The Untouchable
Ballarat
Re: Cheap 3t block and one 3t piston needed :s Sun, 27 June 2004 18:17 Go to previous messageGo to next message
blingin, im going to talk to mnw and see whats happening in regard to my block, hopefully the head isnt too damaged and its worth doing again. Mad . im looking at putting forgies in it, but as soon as i know, ill let you know Smile
thanks, gw
The Untouchable
Ballarat
Re: Cheap 3t block and one 3t piston needed :s Sat, 10 July 2004 08:38 Go to previous messageGo to next message
hey guys,
ive decided that i cant afford to put forgies in it and get bored out, so im now once again looking for a cheap 2t block.
fergs, i dunno exactly how to get that block of urs to my place in a cheap enoug manner :s, but any good suggestions and we'll go to work. Smile
thanks guys
fade-e
Re: Edit: 2t block needed Sat, 10 July 2004 08:49 Go to previous messageGo to next message
im in SYD and have a 3T without dizzy or carby, but 2T ones will fit for sure Smile
im asking for $100 but may need reco cause not sure how long since its been started... i dont know what postage to you would be though
fergo308
Eastern Sydney
Re: Edit: 2t block needed Mon, 12 July 2004 09:50 Go to previous message
best bet would be to get in touch with a courier and organise to get it put on someone's regular interstate run. that'd be the cheapest way,other than someone picking it up for you...
let me know if you get something organised. pick up would be from syd metro.
Justin...
0418 663628
Previous Topic:ta22 roof lining
Next Topic:5m or 7m to w58 bellhousing
Current Time: Sat Oct 24 01:40:40 UTC 2026
Total time taken to generate the page: 0.0040879249572754 seconds
