Toymods » Tech & Conversions » (EDIT) vl fuel pump. now with part no#
people100
Rocklea qld
(EDIT) vl fuel pump. now with part no# Thu, 24 June 2004 10:03 Go to next message
will a standard vl fuel pump run a 300+ hp 18rgteu or would i need a vl turbo pump. is there any differences.
The part number is a bosch 0 580 464 050 anyone know about theses
[Updated on: Sun, 27 June 2004 08:49]
chrizer
Re: vl fuel pump Thu, 24 June 2004 10:07 Go to previous messageGo to next message
I've heard that the vl and vl turbo pumps are exactly the same.
Spanktown
Inside a giant turbo (syd...
Re: vl fuel pump Thu, 24 June 2004 10:38 Go to previous messageGo to next message
i have also heard this and would like to know for sure.
mrf_ool
Taree (4 hrs north of syd...
Re: vl fuel pump Thu, 24 June 2004 11:07 Go to previous messageGo to next message
been told the turbo ones are better ..aslong as its a bosh one the after market ones fuck up
sideshow
Re: vl fuel pump Thu, 24 June 2004 11:27 Go to previous messageGo to next message
vl turbo ones flow more than the vl non turbo
and the injected v8's with external pump used the vl turbo pumps too
the holden v6s had diff pump
people100
Rocklea qld
Re: vl fuel pump Fri, 25 June 2004 09:39 Go to previous messageGo to next message
so would a vl standard external pump do the job for me or should i start looking elsewhere for a pump???
Fattony
Re: vl fuel pump Fri, 25 June 2004 09:54 Go to previous messageGo to next message
Yes with a VLTURBO fuel pump and a higher than stock fuel pressure it is quite concievble that this pump could deliver 300hp worth of fuel considering on a vl turbo with the right boost, cooler ect, and a decent fuel pressure reg you can get this output with the standard pump, i cant see you having a problem.
people100
Rocklea qld
Re: vl fuel pump Fri, 25 June 2004 10:48 Go to previous messageGo to next message
Sorry. Im a bit confuessed. Were u saying vl pu8mp was good enough or VLTURBO pump??? sorry once again
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: vl fuel pump Fri, 25 June 2004 10:57 Go to previous messageGo to next message
VL non turbo and turbo pumps are exactally the same, check the part numbers for yourself.
Re: vl fuel pump Fri, 25 June 2004 11:23 Go to previous message
Apparently the factory-installed pumps were different between the NA and turbo models, but the replacement item is now listed (by Holden) as the same pump for both models. In other words, they changed it at some point; hence the widespread confusion on this topic!
Previous Topic:4AGZE ABV Problems
Next Topic:Salibury diff
Current Time: Tue Nov 24 21:03:33 UTC 2026
Total time taken to generate the page: 0.0059418678283691 seconds
