Toymods » Tech & Conversions » Accessories to Ignition
BreadNut
Accessories to Ignition Thu, 24 June 2004 14:11 Go to next message
a hoi hoi
i've set up my head unit but the accessories aint working cos my stuff on the head unit ain't resuming.
So am i able to just connect a clean wire from the accessories of the head unit to the ignition switch?
and if i could is it easy access for wiring, like should i be able to just solder on the wire on the back of the ignition switch or do i have to do something else
thx
p.s - toyota corolla ae92 hatch
Celica_John
Re: Accessories to Ignition Fri, 25 June 2004 02:47 Go to previous messageGo to next message
When ever i'v put a head unit in i just start poking wires with a test light while turning the accessories on and off and find power that way.
Re: Accessories to Ignition Fri, 25 June 2004 03:37 Go to previous messageGo to next message
There should already be a circuit in the dash for this very purpose. Try to get a circuit diagram for your car and you'll be able to work out which wire it is. Definitely don't solder any wires directly to your ignition switch; as a last resort you could run a feed off the accessories circuit from the fuse box, but the best way to do it is to find the original circuit for the factory radio.
Maurice c
Re: Accessories to Ignition Fri, 25 June 2004 23:43 Go to previous message
Look at the wireing at the back of your head unit. There should be a couple of adaptors to change the power options. You might be able to run both the accesories and permanent live off the one permanent live feed.
Previous Topic:Timing Chain stuffed - no, it's all good now.....or is it?
Next Topic:puzzled about wheel bolt pattern. help..
Current Time: Fri Nov 20 06:50:47 UTC 2026
Total time taken to generate the page: 0.0052139759063721 seconds
