Classifieds » Parts Wanted » TA22 T-series diff
demuire
Ipswich
TA22 T-series diff Thu, 24 June 2004 23:53 Go to next message
Looking for a TA22 T-series diff complete, preferably with the rear yoke from the tailshaft too (modifying to put into a KE Corolla).
In Brisbane, can pick up.
ra_28
Re: TA22 T-series diff Fri, 25 June 2004 02:37 Go to previous messageGo to next message
U should be looking for a ra23/28 diff there the same but the 23/28 is stronger. I have a 28 diff with disc brakes off a trx blue bird and a tail shaft the centre is blowen but u can have the diff for $100.
demuire
Ipswich
Re: TA22 T-series diff Fri, 25 June 2004 02:48 Go to previous messageGo to next message
Stronger? In what way? They're both T-series yes?
How wide is the RA23/28 diff? Is it wider than TA22? If it is the same width (or similar) would be interested, pending condition of the rest of the bits... Where in Brisbane are you?
ra_28
Re: TA22 T-series diff Fri, 25 June 2004 03:01 Go to previous messageGo to next message
I live on the south side in Rochedale. I'm only going on what i've been told by members in the celica club. The reason i took the diff out of the celica other than that i blew it up was because i got hold of a cut down hilux diff. The measurements of the diff are 1370mm from end to end there abouts.
demuire
Ipswich
Re: TA22 T-series diff Fri, 25 June 2004 03:17 Go to previous messageGo to next message
Been doing a bit of poking around, apparently the RA23 diff is only marginally wider than the KE35 one so that's all good. However with the disc rear end it may be different, can you measure the diff from wheel mounting face to mounting face? I've got a spare KE35 diff at home I'll measure tonight.
So the diff is complete with axles, brakes etc, pretty much ready to go (obviously I'd need to modify the mounts...) except for the center? Tail shaft is 1 piece?
Will you be home Saturday arvo? If so I might come and have a look. PM me your phone number or something and I'll give you a call...
Ta Smile
demuire
Ipswich
Re: TA22 T-series diff Fri, 25 June 2004 03:18 Go to previous messageGo to next message
Oh yeah, what sort of handbrake cables does it use with the disc rear end? If they are different, do you have them? Or do you know what car they come out of (I'd be guessing TRX but maybe different because of different length)?
ra_28
Re: TA22 T-series diff Fri, 25 June 2004 03:32 Go to previous messageGo to next message
The hand brake cable is there not sure what it is off i think it might be made up. That measurement that i gave u was mounting surface to mounting surface but it is complete. Alex 0413669256
demuire
Ipswich
Re: TA22 T-series diff Fri, 25 June 2004 03:48 Go to previous messageGo to next message
Excellent. Have something on in the morning till arvo tomorrow, will give you a call after and if you're home might come round.
Thanks!
HYPA-NOVA
Brisbane QLD
Re: TA22 T-series diff Sat, 26 June 2004 13:22 Go to previous message
let me know if he doesn't buy the diff+ disk brakes.
I will take the diff with disk brakes off your hands if you like
Previous Topic:SYD - 4AGE Powersteering
Next Topic:'
Current Time: Thu Nov 19 12:01:22 UTC 2026
Total time taken to generate the page: 0.006843090057373 seconds
