Toymods » Tech & Conversions » 4AGZE ABV Problems
takai
4AGZE ABV Problems Fri, 25 June 2004 02:51 Go to next message
Ive been having these problems for a while now, but can only be bothered fixing it about now.
On my AE92 MAP GZE the idle occasionally bounces and threatens to stall. Everything ive seen points to the ABV being at fault as it does this only when warm, so the idle control is doing its job.
The MAP sensor doesnt give weird readings during this time although it would be interesting to see what i get with an analogue reading rather than the digital one off the SAFC.
I know a couple of people on here have blanked off their ABV entirely and removed it from the engine. And ive heard mumblings about replacing the ABV with a BOV type setup.
What are the details behind either of these?
feral4mr2
Bundaberg, Qld.
Re: 4AGZE ABV Problems Fri, 25 June 2004 02:59 Go to previous messageGo to next message
throw the ABV away or use it as a sinker next time you go fishing. Razz
make a aluminuim plate to bolt where it was and cap the pipe from the s/c outlet pipe. IMO it's not needed.
Ben Wilson
Re: 4AGZE ABV Problems Fri, 25 June 2004 03:05 Go to previous messageGo to next message
If you're in Canberra, drop me a line, my ABV is out of the car at the moment and we can try swapping them over.
I think I've got a blanking setup floating around somewhere too...
takai
Re: 4AGZE ABV Problems Fri, 25 June 2004 03:06 Go to previous messageGo to next message
Yeah im in Canberra atm. Here for a few weeks.
Will drop you a line.
william68
Re: 4AGZE ABV Problems Fri, 25 June 2004 03:45 Go to previous messageGo to next message
what you did before having this problem ?
^ _ ^
takai
Re: 4AGZE ABV Problems Fri, 25 June 2004 07:01 Go to previous messageGo to next message
I put the engine in.... uhhhhh.
The ABV leaks after a long period of use, its a common thing.
william68
Re: 4AGZE ABV Problems Fri, 25 June 2004 11:30 Go to previous message
How it leaks ? Boost leaks but it stalling i thought its not opening/bypassing the air.
Previous Topic:windscreen mounting
Next Topic:(EDIT) vl fuel pump. now with part no#
Current Time: Tue Nov 24 20:55:55 UTC 2026
Total time taken to generate the page: 0.14344811439514 seconds
