Toymods » Tech & Conversions » diff ratio and wiring
fade-e
icon5.gif  diff ratio and wiring Fri, 25 June 2004 08:08 Go to next message
Hi Peoples!
Please let me know if im posting this in the wrong place but im not sure where to post my Qs.
My first Q is this: -
Im looking in te for sale section at diffs and you guys are always talking bout diff ratios and what not. now i know what the ratios mean and stuff but how do i determine what is good for me? higher ratios are good for what? and vice versa for low ratios?
My second Q is: -
Where is a good place to get my TA22 wired up? the whole wiring system is there and all converted for the TA but lying on the floor and i wouldnt know where to start to piec it together so i wanted some rcommendations for places that have done this and are good priced or who can re wire the whole thing from scratch? also any idea on price for this?
thanks guys
sideshow
Re: diff ratio and wiring Fri, 25 June 2004 08:29 Go to previous messageGo to next message
i can rewire yr car
it is not cheap to rewire it
give me a call on
0415 904 947
but it wont be cheap
i dont do cheap stuff
i prefer to do it right the first time
fade-e
Re: diff ratio and wiring Fri, 25 June 2004 08:35 Go to previous messageGo to next message
Embarassed it would be good if i mentioned the engine hey! its a 3TGTE
sideshow ill call you tomorrow if thats ok?
sideshow
Re: diff ratio and wiring Fri, 25 June 2004 09:27 Go to previous messageGo to next message
ok call me after 3 pm
as ill be runnin round during the mornin
fade-e
Re: diff ratio and wiring Sun, 27 June 2004 07:20 Go to previous messageGo to next message
BUMP
TheStitt
Membership Secretary
Re: diff ratio and wiring Sun, 27 June 2004 07:45 Go to previous messageGo to next message
A low ratio i.e. closer to 1.1 will make a good high way gear, where as a gear that is futher away from 1.1 will be a good tourque, acceleration ratio. Thats the long and short of it.
example with my wagon, its was reving to hard at 110kph with the 4.1:1 ratio however it took of hard as, now with the 3.5:1 ratio it cruises nicely however still takes off well.
As for knowing what you need experiment is one way, the other is to check out the donor cars diff ratio, look at what type of motor you are using and what your 5th gear ratio is and look at the diff ratio. You would want to have them close to a factory car as this will bring you out pretty close to where you want to be.
I'm in a hurry I could explain it a little better with more time.
Luke
fade-e
Re: diff ratio and wiring Sun, 27 June 2004 07:52 Go to previous message
THNKS FOR THAT LUKE!!! Smile
i get your drift and will look into it further myself but i appreciate your info.
Previous Topic:engine conversion legality???
Next Topic:1GGZE Electronic Dizzy
Current Time: Thu Nov 19 16:04:25 UTC 2026
Total time taken to generate the page: 0.012747049331665 seconds
