Toymods » Tech & Conversions » Do W box slave cyls come in different bore sizes?
Shotgun
Auckland, New Zealand
Do W box slave cyls come in different bore sizes? Fri, 25 June 2004 18:05 Go to next message
In my JZZ30 I'm using a JZA80 clutch master/pedal with the normal W box style slave. I'm not getting enough slave travel. Does anybody know if there is an externally identical slave that comes in a smaller bore? Isn't the T box one similar?
Any help would be greatly appreciated. Cheers. Very Happy
V8_MA61
Re: Do W box slave cyls come in different bore sizes? Sat, 26 June 2004 07:13 Go to previous messageGo to next message
w55,57,58 all have the same piston size. not sure on r154, but im using a w58 slave cylinder, so i cant see you having any problems!
Shotgun
Re: Do W box slave cyls come in different bore sizes? Sat, 26 June 2004 19:37 Go to previous messageGo to next message
But what master cyl are you using and how much travel do you get?
toynado
Re: Do W box slave cyls come in different bore sizes? Sat, 26 June 2004 21:18 Go to previous messageGo to next message
the 22ret has a different slave cylinder than the 22re
the turbo has a larger clutch
i dunno wut the exact difference in slave cylinders is
mine has a w56 tranny
V8_MA61
Re: Do W box slave cyls come in different bore sizes? Sun, 27 June 2004 08:22 Go to previous messageGo to next message
22ret? Wtf?
V8_MA61
Shotgun wrote on Sun, 27 June 2004 05:37
stock ma61 master cylinder
toynado
Re: Do W box slave cyls come in different bore sizes? Sun, 27 June 2004 19:14 Go to previous message
22ret came out in the us in 86 i believe
they put a small turbo on the 22re in trucks
it adds about 25 hp as i remember
and has sum overheating issues if not cared for well
new pistons and head from the factory
peepl hav got over 500 hp outta a 22re with bigger turbos
using the stock crank which apparently is pretty tough
Previous Topic:what studs to use in manifold
Next Topic:removing air flow meter on 4AC
Current Time: Fri Nov 20 04:27:09 UTC 2026
Total time taken to generate the page: 0.0041561126708984 seconds
