Classifieds » Miscellaneous » *SOLD* 18R-G Head + injection manifold f/s
RA23_Sean
Western Sydney
*SOLD* 18R-G Head + injection manifold f/s Sat, 26 June 2004 02:39 Go to next message
Alright. I've got an 88253 head with the standard 88270 injection manifold on it. It's got large cams (never knew the specs, but they were lumpy. Cams came on at 4000-4500 and went to 7000rpm.
The head is missing the cam gears and gear retaining bolts (accidentally left them in the boot of my Celica when I had it towed away).
Manifold has standard injectors and a Falcon fuel pressure regulator. There is no loom and no computer.
I also have an R-GEU air flow meter with uni-filter ram pod (needs a new filter element). The spring tension in the AFM was adjusted to suit the big cams on the above head.
I have both R-G rocker cover styles.
Lastly, I have the R-G electronic distributor.
All of this I'm giving away for $300. I've got a guy who told me he'd buy the bits, but he's screwing me around.
Head was only removed because the bottom end failed. (Thanks to the dodgy prick who built it).
Call me on 0439 60 20 60 for any details. I live in Western syd and work in Hornsby, so may be able to arrange to drop parts off if convenient.
[Updated on: Sun, 27 June 2004 07:53]
omegaman
SYDNEY
Re: 18R-G Head + injection manifold f/s Sat, 26 June 2004 04:21 Go to previous messageGo to next message
can you quote the numbers on the cams for us. please.
edwin
Victoria, near Frankston
Re: 18R-G Head + injection manifold f/s Sat, 26 June 2004 10:44 Go to previous messageGo to next message
I may be interested, photo?
RA23_Sean
Western Sydney
Re: 18R-G Head + injection manifold f/s Sun, 27 June 2004 01:02 Go to previous messageGo to next message
Omegaman, what do you need the numbers on the cams for? I'll get back to you sometime this arvo with the numbers. They're standard cams that have been reground. ~3mm shims were needed to get correct valve clearances.
RA40Celica
Hobart
  chris_rg@jabber.org
Re: 18R-G Head + injection manifold f/s Sun, 27 June 2004 05:26 Go to previous messageGo to next message
Would you be interested to split some of these things up?
u would probably make more than $300 selling individual parts.
i'm interested in the cams. Any problem posting them to tassie?, i pay postage of course.
What was the idle like with those cams?
Chris
RA40Celica
Hobart
  chris_rg@jabber.org
Re: 18R-G Head + injection manifold f/s Sun, 27 June 2004 05:37 Go to previous messageGo to next message
also, do you happen to have an 18rgeu thermo housing?... the lower part with holes for sensors?.. i need one of these pretty bad.
Chris
RA23_Sean
Western Sydney
Re: 18R-G Head + injection manifold f/s Sun, 27 June 2004 07:52 Go to previous message
It's all been sold and I don't have another thermo housing. As of today I am finally rid of all my Celica parts - well that is except for an RA23 front grille.
Previous Topic:lock diff
Next Topic:4AC RWD starter
Current Time: Sun Oct 25 12:50:00 UTC 2026
Total time taken to generate the page: 0.0043919086456299 seconds
