Toymods » Tech & Conversions » Corolla FWD to RWD/4WD Conversion
Hatchetman
Corolla FWD to RWD/4WD Conversion Sun, 27 June 2004 05:39 Go to next message
Hey everyone,
I am a fairly new poster (been readin a while) to this forum and would like to ask you knowledgeable Toyota buffs (is that enough sucking up? lol) a couple of questions before I buy my next car.
Has anyone here done a FWD to RWD/4WD conversion on a late model corolla?
I am considering buying a '99 AE111 BZ-R Trueno (with the 6sp 20V 4A-GE engine)which come factory fitted as FWD, once the compliance is available. Shocked
I know theres a few different Toyota's that came in 4WD layout (the Corolla wagon etc.) and am wondering if the drivetrain from one of these cars would fit the AE111 (Jap Spec)?
If this could be done I have considered transplanting the 20V with a 3S-GTE (in either 4WD or RWD configuration) down the track when I want more power. Evil or Very Mad
I guess what I really wanna know is that if I get one of these, is it worth trying to convert to RWD/4WD or will it be so expensive that I am better off keeping it FWD...or building up an AE86? Rolling Eyes
[Updated on: Sun, 27 June 2004 08:02]
Hatchetman
Re: AE111 BZ-R Trueno FWD to RWD/4WD Conversion Sun, 27 June 2004 05:41 Go to previous messageGo to next message
LOL just read my own post, how confused do I sound! Very Happy
SW20R
Re: Corolla FWD to RWD/4WD Conversion Sun, 27 June 2004 08:26 Go to previous messageGo to next message
why are you so eager to change it to rwd?
why not just buy an rwd car already?
you will need alot of work and $$$ todo this
parts, engineering, paper work and legalities.
If you want a 4WD toyota then get a GT4.
But honnestly the only real market rwd cars you want are made by nissan these days everyone else has gone soft and changed to fwd.
The AE111 Might look good but leave it as it is. It was designed FWD. Take a look at the Integra its fwd and is pretty quick on the track. Making it fast is upto you and how well you can drive not what the drive train is.
Johnny
Sydney, OZ
Re: Corolla FWD to RWD/4WD Conversion Mon, 28 June 2004 01:00 Go to previous messageGo to next message
Got $150K? Can get you a Nice AE111 2nd already with 300BHP 3sgte, xtrac squential G/Box, three active diff's , Ohlins suspension, Custom Toyota Graphics standard, 3" harness's.... did I mention it was used by Neal Bates?
Really, the Floor pan of the AWD wagons from Japan are different, you could cut and weld these in place along with all the drive componets, again, you need a bucket load of money to do and it would still be cheaper to by a GT4... seen a nice one GPA for sale $16,000 yesterday....
wagonist
Toymods Club Treasurer
Re: Corolla FWD to RWD/4WD Conversion Mon, 28 June 2004 22:56 Go to previous message
Fensport did this to a Corolla in the UK
http://www.fensport.co.uk/fensportcars.htm
I am currently sourcing bits to convert my Caldina to 3S-GTE & 4wd, but option of my car was a 3S-GE & 4wd.
Considering this, here is a list of things to do so I can get the 4wd to work:
Bits to buy:
4wd engine crossmembers (FWD are in the way of tailshaft)
4wd rear suspension complete, including struts
4wd fuel tank
tailshaft
4wd gearbox, front shafts, starter motor
Work required:
cut off brackets holding on current rear suspension
weld in captive nuts to existing holes in rear chassis
drill new holes & weld in captive nuts in rear chassis
bolts everything up
I consider this an fairly "easy" job & is helped by there being a higher proportion of 4wd Coronas & Caldinas than Corollas.
The only late model 4wd Corolla is the wagon, whereas 4wd is an option on any Corona or Caldina, therefore the floorpan is more interchangeable.
My estimate:
gearbox (ST205), front shafts, flywheel, starter motor....$1500
rear suspension (including LSD)...........................$1500
fuel tank.............................................. ...$ 250
front crossmembers...................................... ..$ 300
Welding........................................... ........$????
I'm also planning on an engine change at the same time, so add another $3000 for GenIV 3S-GTE
If you've got the money though, I think it would be an awesome machine
Previous Topic:what diff ratio for me.
Next Topic:backspacing?
Current Time: Fri Nov 20 18:00:21 UTC 2026
Total time taken to generate the page: 0.0057609081268311 seconds
