Toymods » Tech & Conversions » Is this serious?
Camry_omega
Campbelltown, NSW, Austra...
Is this serious? Sun, 27 June 2004 05:40 Go to next message
Hey, my sv21 seems to be going through a bit of coolant of late, also im finding some dried up white residue on the engine block, under the exhaust manifold which leads me to belive coolant is leaking through the head gasket??
Also when i push the throttle hard i get some black soot out the exhaust, and i seem to be running low on oil sometimes.
The car's engine is a 3s-fe and has done 207,000 kms, are these things indicators of something serious about to happen to the engine, if so should i get it looked at now, or wait untill something goes wrong?
RWDboy
Re: Is this serious? Sun, 27 June 2004 06:19 Go to previous messageGo to next message
It could be serious Smile
Black soot is probably not such an issue.
207,000kms is a fair few kilometers so I'd expect the engine to start going kooky if it hasn't been regularly/properly serviced from the day it left the factory.
Toobs
Re: Is this serious? Sun, 27 June 2004 06:27 Go to previous messageGo to next message
Camry_omega wrote on Sun, 27 June 2004 15:40
1) seems to be going through a bit of coolant of late
2) dried up white residue on the engine block, under the exhaust manifold
3) when i push the throttle hard i get some black soot out the exhaust
4) i seem to be running low on oil sometimes
5) has done 207,000 kms
Points 1,2,4 could all be BHG related
Point 3 is most likely just condensation blowing out of your exhaust and bringing some carbon with it.
Depends when it happens though... what I have said would be true for when you've just started the car first thing in the morning
Points 1,2,4,5 tell me you're probably going to need to do some work sometime soon so maybe this will be a good opportunity to install a 3SGTE Very Happy
Camry_omega
Re: Is this serious? Sun, 27 June 2004 06:29 Go to previous messageGo to next message
Yeah but i think the auto gear box wouldn't be able to take the power, at which point it would probably be cheaper to buy a better car
Toobs
Re: Is this serious? Sun, 27 June 2004 06:37 Go to previous messageGo to next message
Hmm... You'll probably find that it will take the power of a 3SGTE... only two ways to find out:
1) Find someone else who's done it
2) Install the engine and if the gearbox breaks it couldn't handle it Evil or Very Mad
Camry_omega
Re: Is this serious? Sun, 27 June 2004 06:41 Go to previous messageGo to next message
LOL, thats one way to find out.
How costly would all this be?
RWDboy
Re: Is this serious? Sun, 27 June 2004 06:43 Go to previous messageGo to next message
Can probably pick up a half cut 3S-GTE (1st gen) for near to $2000 from an importer...of course, 2nd gen are easier to come by but usually more expensive.
Camry_omega
Re: Is this serious? Sun, 27 June 2004 06:45 Go to previous message
If i was to do a convesion i would be more inclined to get a st-162/184 first, because it would be easier refine the handling.
Still its worth considering.
Previous Topic:Gaskets for 1GGTEU
Next Topic:CONV: TA22 2T from Points to Electronic
Current Time: Thu Nov 19 14:11:29 UTC 2026
Total time taken to generate the page: 0.0063478946685791 seconds
