Toymods » Tech & Conversions » MX83 strut/ Ba coon brake upgrade Question:
V8_MA61
MX83 strut/ Ba coon brake upgrade Question: Sun, 27 June 2004 08:18 Go to next message
does anyone know if the Conversion using the 298mm Coon discs, and R33 gtst calipers Fits inside a 16" rim??
Blake
Re: MX83 strut/ Ba coon brake upgrade Question: Mon, 28 June 2004 00:32 Go to previous messageGo to next message
I think it will be a case of "suck it and see". Some 16" rims may fit while others may not. It will be easy enough to check once you have your struts and discs; I can loan you my calipers (if you don't have any by then) and you can see if one of your MA70 rims fits over them.
Purple_Beasty
New Zealand
Re: MX83 strut/ Ba coon brake upgrade Question: Mon, 28 June 2004 00:57 Go to previous messageGo to next message
Maybe look at Falcon rims, they seem to have a fair bit of clearance. 14 inch Falcon rims fit over 287mm discs from the factory so 298mm and 16's SHOULD be ok. Depends how much the caliper adds to the overall diameter.
Callum
V8_MA61
Re: MX83 strut/ Ba coon brake upgrade Question: Mon, 28 June 2004 01:18 Go to previous message
i spose, come to think of it a stock 15" or 16" ba rim does fit over the 298mm rotors...calipers are where the fitting diameter becomes iffy im guessing.
But norbie thatd be great if i bring it round one day! Smile
Blake
Previous Topic:4age 20v help.
Next Topic:Broken sway bar studs?
Current Time: Fri Nov 20 08:29:24 UTC 2026
Total time taken to generate the page: 0.0067620277404785 seconds
