Toymods » Tech & Conversions » vapour lock? help me make my car move again.
slydar
vapour lock? help me make my car move again. Mon, 28 June 2004 12:48 Go to next message
heres the deal. my sprinter has been sitting around for a good few months.. (2nd one, building it up.. gotta sell my other car first ect...)
it wont go. the battery is dead. no prob, some jumper leads should fix that... wrong. ok, so it cranks good.. but thats all it does.
check spark.. good healthy spark.
check fuel, ive got fuel (new fuel too, i put about 5 litres of NEW fuel in it yesterday) upto the filter(it pours out when i pull the line off the filter).
so what could it be? vapour lock? if so how can i prime the system?
got any other ideas? its just got the 4ac in it right now.
any ideas on what to try/trouble shoot would be great. cheers.
ae95
Re: vapour lock? help me make my car move again. Mon, 28 June 2004 12:52 Go to previous messageGo to next message
after my engine conversion it took a bit of cranking over before it finally started.
[Updated on: Mon, 28 June 2004 12:59]
Re: vapour lock? help me make my car move again. Mon, 28 June 2004 12:53 Go to previous messageGo to next message
Pumps probably crook;-)
Tip a bit down the carb, see if it fires. Don't set yourself alight though!
Re: vapour lock? help me make my car move again. Mon, 28 June 2004 12:58 Go to previous messageGo to next message
I've seen amusing results of people trying this the wrong way.
pour, then move the container of petrol away Smile
slydar
Re: vapour lock? help me make my car move again. Mon, 28 June 2004 12:59 Go to previous messageGo to next message
yeah.. i dont have aero start.. i put a little fuel in a spray bottle i usually use to wet down my brakes before i work on them.. and sprayed it in while my room mate cranked it... nothing.. cleaned the plugs too. didnt have too much fuel to much around with.. not sure he had the throttle open either.. id have to tell him... his mum gave him their old e class (but hes a nice guy).
thing is its a serviced car, and was is fine working order when it was parked. pain in the arse.
i wouldnt even care(i already have my small port waiting).. but it will be real hard to get it out of there not under its own power.
Re: vapour lock? help me make my car move again. Mon, 28 June 2004 13:04 Go to previous messageGo to next message
you need a can of:
http://www.nulon.com.au/images/imglrg_SYBgroup.jpg
slydar
Re: vapour lock? help me make my car move again. Mon, 28 June 2004 13:06 Go to previous messageGo to next message
man, this post has been up all of 3 minutes. and i have 4 replies, including one with a pic' referance.
ill buy some aero start.
Re: vapour lock? help me make my car move again. Mon, 28 June 2004 13:28 Go to previous messageGo to next message
I love 'start ya bastard!' just for the name, but I'm a tightarse an always use petrol Evil or Very Mad Don't get too stingy with it, and use some throttle too. Check the timing as well. Evil or Very Mad
hemi twofifteen turbo
Re: vapour lock? help me make my car move again. Mon, 28 June 2004 14:35 Go to previous messageGo to next message
pour at least a 'shotglass' full down there. (30mls)
make sure it goes IN, past the throttle plate. on some carbies it can sit on top of the secondary butterfly and not go in..
If it first for 2 seconds, and stalls, put in another 30 mls..
and so on. Try rev it, as it 'clears it out', and hopefully the other fuel system will take over.. Esp if it's got a mechanical pump.
funny that I started the old 18r celica just last night wiyh the same method.
allencr
tallahassee FL usOFa
Re: vapour lock? help me make my car move again. Mon, 28 June 2004 15:11 Go to previous messageGo to next message
no, not "vapor lock" when its not running unless you are on Mercury.
does the accelerator pump "squirt"??? then there's no need for anything extra, and certainly not a "shotglass" worth on anything less then 400 cu.in.
what's the compression??
cam and/or ignition timing.
fade-e
Re: vapour lock? help me make my car move again. Mon, 28 June 2004 17:01 Go to previous messageGo to next message
since its carby i recon you look down the carby and accelerate and make sure it is feeding petrol firstly.
do you get any backfire? either from carby side or exhaust, if so then timing.
also the so called healthy spark, is that from the coil lead or have you checked each spark plug as well? you may get good spark when unplug lead from dizzy but a few months of sitting and the dizzy terminals may be coroded. maybe you have checked this but i would ensure there is spark to every lead.
another thing may be dirt in cylinder. for that i just take out all spark plugs and crank it for 30sec and the compression from each cylinder will force any dirt, soot or whatever out
other than that you can just try try and try again till she kicks over. if i leave my 3T carby not started for a week she is a bitch to start. i find carbys tend to dry up quick and if you say its been a few months then she dry as and needs to be made wet Smile
slydar
Re: vapour lock? help me make my car move again. Wed, 30 June 2004 11:34 Go to previous messageGo to next message
cheers all for replies.
it fired using some aero start a mate brought round. i think i just have a clogged jet( suggestion of a ex bike mechanic i work with).
it wont be timing, it hasnt been touched and ran well before it was parked. i had a look inside the dizz aswell. and the spark, i just checked no.1, pulled the lead off and earthed it.
thanks for the help Smile
fade-e
Re: vapour lock? help me make my car move again. Wed, 30 June 2004 11:53 Go to previous messageGo to next message
so she was dry hey? Very Happy the main thing is that you got it started... good one
Super Jamie
On Probation
North East NSW
Re: vapour lock? help me make my car move again. Thu, 01 July 2004 05:45 Go to previous messageGo to next message
fade-e wrote on Tue, 29 June 2004 03:01
NO!!!
do not look down a carburettor on an engine that has ANY possibility of backfiring, as yours does, some might even say never look down a carburettor full stop. if it backfires up at you and you're lucky you'll get away with singed eyebrows, it only goes downhill from there, especially if it blows a stack of fuel droplets back up at your face, as carbs often do. if you must look down the carburettor, go buy a $2 mirror from a cheap shop
fade-e
Re: vapour lock? help me make my car move again. Thu, 01 July 2004 07:45 Go to previous message
i meant to look down carby while not starting the car to see if fuel gets fed through.
YOU GOTTA BE CRAZY & Razz TO LOOK WHILE TRYING TO START IT
Previous Topic:How to tell the difference between a different gen 1G's
Next Topic:sc14 brackets
Current Time: Fri Oct 16 13:05:26 UTC 2026
Total time taken to generate the page: 0.046408176422119 seconds
