Toymods » Tech & Conversions » 4age lifespan and White smoke.
wiso
icon9.gif  4age lifespan and White smoke. Mon, 28 June 2004 15:09 Go to next message
Just wondering how many here have had a 4age do their head gasket, cause I have had 3 friends with AE82 rollas, and funny enough they all did their head gaskets at 350,000kms, is this a common trait of the 4age or can they go longer?
Also mine currently has 230,000km on the clock it's blowing some white smoke, I was think ing head gasket gone, but the bubble test is negative anf there is no oil and water mixing, So I was told it could be the valve stem seals? how does that sound? I plan to try and do a compression test asap, that should hopefully tell me what may be wrong.
SPRINTAH!
Re: 4age lifespan and White smoke. Tue, 29 June 2004 08:03 Go to previous messageGo to next message
it would be either your valve atem seals or rings.
if the smoke is mainly apparent after you leave it idleing for a long time or when the manifold is under high vacuum, then its most likely your stem seals.
wiso
Re: 4age lifespan and White smoke. Wed, 30 June 2004 04:47 Go to previous messageGo to next message
can you do them from the top like you can with some older engines or do you have to pull the head off to do them? if thats the case may be time for a minor self reco.
the first time it started (in 2 years) it blew white smoke immediatly, the next time it idled for a while before it started to smoke.
[Updated on: Wed, 30 June 2004 04:48]
ae824age
Re: 4age lifespan and White smoke. Wed, 30 June 2004 06:42 Go to previous message
My 86kw FWD died at 218,000 (Head Gasket) Sad
Damn bogans thrahsed it in 1987 listening to Australian Crawl Mad
Previous Topic:Anyone have someRA60/Sa63/ra65 front strut inserts they could measure for me?
Next Topic:air conditioning compressor
Current Time: Fri Oct 23 12:05:31 UTC 2026
Total time taken to generate the page: 0.0055639743804932 seconds
