Toymods » Tech & Conversions » 3s engine number - where?
._T_.
3s engine number - where? Mon, 28 June 2004 22:33 Go to next message
well i carefully recorded the engine number before fitting the engine into my mr2. now the car is all up & running and ready for engineering, but i can't find the piece of paper with the number on it!!
engine bay is very crampt so i can't see the engine number - anyone know exactly where it is is i can take a tracing etc of it? from memory it was near the distributor end of the motor.......
Ta
T
takai
Re: 3s engine number - where? Mon, 28 June 2004 22:56 Go to previous messageGo to next message
Pretty sure its on a flat section of block just past the 4th cylinder. Exhaust side naturally.
Similar position to the 4As if i remember correctly.
510rob
Vancouver
Re: 3s engine number - where? Mon, 28 June 2004 23:33 Go to previous messageGo to next message
If you were looking end-on at the distributor end of the motor, the numbers are stamped into the top edge of the block - the 3S is on the left side, and the serial number is on the right side.
._T_.
Re: 3s engine number - where? Mon, 28 June 2004 23:54 Go to previous messageGo to next message
ta chris - did you get the tensioner bearing?
rob- thanks
- i'll check it out - as to how i don't know yet.......(space is at a primium in there!!!)
i'm thinking plastacine at this point.....
Smile
510rob
Vancouver
Re: 3s engine number - where? Tue, 29 June 2004 00:46 Go to previous messageGo to next message
A piece of white masking tape might work if you rub a pencil across it once it's in there?
rub a cloth with alcohol on that surface so the tape will stick, then stick a piece of thin tape in there, then gently rub the tape with a pencil, then peel the tape off the block? It might work...
._T_.
Re: 3s engine number - where? Tue, 29 June 2004 00:53 Go to previous messageGo to next message
i'll give it a try!! - engine no & car weight - the last 2 things to do until i get the dratted thing engineered!!!
T
CLG
Perth, Western Australia
Re: 3s engine number - where? Tue, 29 June 2004 01:28 Go to previous messageGo to next message
Yep, back of the block just below the head. Have you tried a mirror and light too? I use a broken piece of wing mirror and break it to suit the job.
510rob
Vancouver
Re: 3s engine number - where? Tue, 29 June 2004 01:44 Go to previous messageGo to next message
what car are you building up? is it a RWD 3S application?
takai
Re: 3s engine number - where? Tue, 29 June 2004 01:54 Go to previous messageGo to next message
Its RWD just not the usual RWD.
And if you read his post correctly you would find all.
Joshstix
Toymods Vice President
Re: 3s engine number - where? Tue, 29 June 2004 02:03 Go to previous messageGo to next message
I had to ask the same question recently and even though I now know where the engine number is I'll be stuffed if I can see it.
Just for future refference the number is at:
http://www.mr2-tech.com/bgb/mechanical/volume1/introduction/Manual_006_0001.jpg
510rob
Vancouver
Re: 3s engine number - where? Tue, 29 June 2004 02:08 Go to previous messageGo to next message
oh yeah... duuuh, there it is right there... MR2!
._T_.
Re: 3s engine number - where? Tue, 29 June 2004 04:21 Go to previous message
aw11. aus delivered. with t-bar roof.
josh - thanks for the diagram.
aagghhh!! can't get to it - have to pull 1/2 the car apart tonight to hopefully get it! drat.
odd are as soon as iv'e done it i'll find the carefully secreted bit of paper with hte number on it.
T
Previous Topic:Lexan glass
Next Topic:w/washer motor wiring -all 3 positive ???
Current Time: Wed Sep 16 10:49:44 UTC 2026
Total time taken to generate the page: 0.066870927810669 seconds
