Toymods » Tech & Conversions » air fuel ratio meter
pulcino
Mackay QLD
air fuel ratio meter Tue, 29 June 2004 10:30 Go to next message
Has anyone built and used the jaycar air fuel ratio meter with the leds.Does it work? I just want peace of mind that it doesnt lean out again at high boost rpm?
ed_ma61
Lost in the K hole
Re: air fuel ratio meter Tue, 29 June 2004 10:33 Go to previous messageGo to next message
yes it works, and work pretty damn well for what you want (ie dangerously lean mix identification). dont expect to tune your engine by it though...
pulcino
Mackay QLD
Re: air fuel ratio meter Tue, 29 June 2004 10:45 Go to previous messageGo to next message
do they make a case for it?
SeptemberSquallIndustries
Re: air fuel ratio meter Tue, 29 June 2004 12:37 Go to previous messageGo to next message
Nup. You're meant to be a geek; ie. oooh, circuit boards...!
TA-022
Glenmore Park, NSW
Re: air fuel ratio meter Tue, 29 June 2004 13:46 Go to previous messageGo to next message
http://www1.jaycar.com.au/productView.asp?ID=KC530 0&CATID=&keywords=fuel+mixture&SPECIAL =&form=KEYWORD&ProdCodeOnly=&Keyword1= &Keyword2=&pageNumber=&priceMin=&p riceMax=&SUBCATID=
^--- comes with case.
STOCK-CODE: KC5300 RRP: $62.95
Qty 1+ $62.95 Qty 5+ $56.50
Digital Fuel Mixture Display Kit for Cars
Kit includes case with PCB¹s, pre-programmed PIC micro, 7 segment displays, red acrilic, hook-up wire and all electronic components.
- Case includes a laser cut & silk screened front panel
- Clamp included
http://www1.jaycar.com.au/productView.asp?ID=KC537 4&CATID=&keywords=fuel+mixture&SPECIAL =&form=KEYWORD&ProdCodeOnly=&Keyword1= &Keyword2=&pageNumber=&priceMin=&p riceMax=&SUBCATID=
^-- seems like no case
STOCK-CODE: KC5374 RRP: $27.95
Qty 1+ $27.95 Qty 5+ $24.95
Smart Fuel Mixture Display for Fuel injected Cars
Kit supplied with PCB and all electronic components.
* Car must be fitted with air flow and EGO sensors (standard on all EFI systems) for full functionality.
Search is your friend.
Nathan
pulcino
Mackay QLD
Re: air fuel ratio meter Tue, 29 June 2004 20:35 Go to previous messageGo to next message
I had searched and knew what they were and where to get them but just diddnt know if they were any good.
Re: air fuel ratio meter Tue, 29 June 2004 21:56 Go to previous messageGo to next message
If you want a meter accurate enough have a look at Techedge's meters. They are half the price of the big name brand ones and seem to have a good wrap.
pulcino
Mackay QLD
Re: air fuel ratio meter Wed, 30 June 2004 04:42 Go to previous messageGo to next message
they are expensive.I just want a reliable heads up if the car leanes out.I have the dyno for tuning.
TA-022
Glenmore Park, NSW
Re: air fuel ratio meter Wed, 30 June 2004 12:19 Go to previous messageGo to next message
pulcino wrote on Tue, 29 June 2004 20:45
just answering a q
Nathan
Re: air fuel ratio meter Wed, 30 June 2004 13:00 Go to previous messageGo to next message
pulcino wrote on Wed, 30 June 2004 14:42
these will only tell you if you lean out "past stoich"
you may well be dangerously lean before reaching the stoich point..
but yeah, as a rough n ready cheap check... better than nothing.
pulcino
Mackay QLD
Re: air fuel ratio meter Wed, 30 June 2004 22:14 Go to previous messageGo to next message
To my understanding you have to calibrate the operation why couldnt you make it a little more sensative?
Re: air fuel ratio meter Wed, 30 June 2004 23:08 Go to previous messageGo to next message
Conventional narrow-band EGO sensors can only tell you if the mixture is at stoich, above stoich, or below stoich. This is fine if you're trying to trim the fuel mixtures at cruise for optimum fuel efficiency (that's what they're designed for), but pretty useless for anything else. If you want to know what the fuel mixtures are doing under any other circumstances, you need a wide-band EGO sensor.
pulcino
Mackay QLD
Re: air fuel ratio meter Thu, 01 July 2004 06:55 Go to previous messageGo to next message
I fully understand all that. I do my tuning on the dyno.All i want is a buzzer or a light that under full boost will tell me if I suffer a lean out. Which is what made me blow the last motor.I dont want to know how lean,what my mixtyres are anything like that just rich stoich or lean. If at full boost it drops even remotely into stoich i can shut down get it to a dyno and check it. sorry a bit frustrated cos i dont think people are getting the gist of what im after.I spent allott of time on the dyno and my motor still blew cos of a freak lean outon the road.
ed_ma61
Lost in the K hole
Re: air fuel ratio meter Thu, 01 July 2004 07:01 Go to previous messageGo to next message
pulcino wrote on Thu, 01 July 2004 16:55
ed_ma61 wrote on Tue, 29 June 2004 20:33
others have repeatedly said the same things...where's the problem?
pulcino
Mackay QLD
Re: air fuel ratio meter Thu, 01 July 2004 07:08 Go to previous message
a little sensative maybe Embarassed
Previous Topic:sc14 brackets
Next Topic:Any Ideas?
Current Time: Sun Nov 22 05:07:10 UTC 2026
Total time taken to generate the page: 0.092702865600586 seconds
