Toymods » Tech & Conversions » TRD susp
Satoshi
TRD susp Wed, 30 June 2004 06:28 Go to next message
does TRD produce coilover (height adjustable and adjustable shocks) for AE86?
and anyone has picture of the trd coilover for ae86 if they do produce them
ae95
Re: TRD susp Wed, 30 June 2004 07:25 Go to previous messageGo to next message
no they dont
they make the springs and shocks.
well kyb makes the shocks
ae86drift
sydney.au
Re: TRD susp Wed, 30 June 2004 07:31 Go to previous messageGo to next message
TRD no longer manufacture ANY ae86 parts as of aug 2003
trd inserts were tokico 102's - which you can still buy from tokico
trs springs were nothing special and copy items can be bought from kg/mm, eibach or even from espelir.
the other components can be bought from anyone online
gabe @ t3 would be my best bet for coilover bits and bobs
Satoshi
Re: TRD susp Wed, 30 June 2004 15:08 Go to previous messageGo to next message
what is the part number for the adjustable shocks ?
and does trd shocks come in black? how do i see the spring rate for the trd spring?
last but not least..how much does the adjustable trd shocks for ae86 go for?
thank you
Satoshi
Re: TRD susp Wed, 30 June 2004 15:17 Go to previous messageGo to next message
anyone who has ae86 trd susp adjustable would be great help too..(the adjuster for the front shocks is located at the camber tops and its red in colour?? 4 way if i am not mistaken?)
thanks..
ae95
Re: TRD susp Wed, 30 June 2004 16:38 Go to previous messageGo to next message
according to the trd site they only made 5 way adjustable front shocks. The adjuster is located at the top of the shaft. Cant remember what colour.
Satoshi
Re: TRD susp Wed, 30 June 2004 16:40 Go to previous messageGo to next message
anyone could spot what's wrong with the coilovers?
if someone told u they are TRD stuff (forget about the struts)...are you skeptical about the front coilovers?
and does the front shocks doesnt look like a short stroke?
http://www.njsr.org/pics/albums/userpics/normal_post-51-1088606735.jpg
[Updated on: Wed, 30 June 2004 16:42]
ae95
Re: TRD susp Wed, 30 June 2004 16:44 Go to previous messageGo to next message
Satoshi wrote on Wed, 30 June 2004 23:08
thank you
all the part numbers and prices are on the trd website. i've seen trd shocks in blue and green. theres probably more colours out there.
trd spring rates here
http://www.dorikaze.com/showthread.php?s=5c13e7b6d 24a23ab4bd66efa41e0be1e&t=17
ae86drift
sydney.au
Re: TRD susp Wed, 30 June 2004 17:46 Go to previous messageGo to next message
i have the TRD bible here
i could consult it
ill check tomorrow for you
Satoshi
Re: TRD susp Thu, 01 July 2004 01:36 Go to previous messageGo to next message
amen
Satoshi
Re: TRD susp Fri, 02 July 2004 07:53 Go to previous messageGo to next message
bump
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: TRD susp Fri, 02 July 2004 08:44 Go to previous messageGo to next message
lmao look at the stroke on them, they most certainly are not short stroke, mine only has around 1 inch total susp travel during max loading, These look like they have around 6+ inches... totally crap.
ae95
Re: TRD susp Fri, 02 July 2004 12:14 Go to previous messageGo to next message
heres mine for comaprisons sake
http://www.skylinesaustralia.com/photopost/data/500/2050105_0503-med.JPG
takai
Re: TRD susp Fri, 02 July 2004 12:40 Go to previous messageGo to next message
Simon-AE86 wrote on Fri, 02 July 2004 18:44
That all depends on spring rates.
Mine will have almost 3" of suspension travel at full loading. a 90mm change.
Almost enough to bottom out the car, if i dont use bumpstops. All depends on how much the springs are loaded up though.
Simon-AE86
Banned user
Re: TRD susp Fri, 02 July 2004 14:22 Go to previous messageGo to next message
too true it does, i have 10kg/mm springs and even 1 inch is a fair bit of travel considering the rates.
i still say the pics posted of those "TRD" coils are dodgy
Satoshi
Re: TRD susp Fri, 02 July 2004 18:26 Go to previous messageGo to next message
the rear shocks is trd but i'm suspecious on the front tho..oh well better luck next time for me
takai
Re: TRD susp Fri, 02 July 2004 23:01 Go to previous messageGo to next message
Those rear shocks arnt Tokicos, they may be GAB 8way though.
Satoshi
Re: TRD susp Sat, 03 July 2004 05:34 Go to previous messageGo to next message
they are TRD...you cant see the part number cause the pic is too small..i got the bigger one with me... Smile
Simon-AE86
Banned user
Re: TRD susp Sat, 03 July 2004 09:40 Go to previous messageGo to next message
TRD greens are povo spec tho
ae95
Re: TRD susp Sat, 03 July 2004 10:46 Go to previous messageGo to next message
You want the blues
Simon-AE86
Banned user
Re: TRD susp Sat, 03 July 2004 15:41 Go to previous messageGo to next message
i have teh blues Wink
ae95
Re: TRD susp Sun, 04 July 2004 08:06 Go to previous messageGo to next message
so do i Smile
Pa2jK
Re: TRD susp Mon, 26 July 2004 07:03 Go to previous message
anyone seen or heard of red trd short stroke ones? whats the diff with the blue ones?
Previous Topic:AW11 brake upgrade
Next Topic:rav4 supercharged air con problems
Current Time: Sat Oct 17 21:23:53 UTC 2026
Total time taken to generate the page: 0.0078310966491699 seconds
