Toymods » Tech & Conversions » 1GGTE clutches
icon5.gif  1GGTE clutches Wed, 30 June 2004 08:18 Go to next message
Hey guys,
Has anyone got a picture of the bigger Gen3 clutch and flywheel? What size is it exactly?
Thanks,
Nathan
CLG
Perth, Western Australia
Re: 1GGTE clutches Wed, 30 June 2004 09:13 Go to previous messageGo to next message
Yep, I want to see it too, and the specific spring and dampner setup in the centre?!
Bugman
Re: 1GGTE clutches Wed, 30 June 2004 10:21 Go to previous messageGo to next message
gen3 gtes have a 9.5 clutch face
I recently fitted a ~760kg pp with a 5 puck sprung center
should do the job.
Siktoy ra23
Plumpton/sydney
Re: 1GGTE clutches Wed, 30 June 2004 12:20 Go to previous messageGo to next message
they are the same as 3tgte clutch plate
Re: 1GGTE clutches Wed, 30 June 2004 23:29 Go to previous messageGo to next message
Bugman wrote on Wed, 30 June 2004 18:21
should do the job.
Are you sure it's that low? The guy where my clutch was dropped off said it was nearly 2000lbs stock, which is way more than 760kg.
Darren
Re: 1GGTE clutches Wed, 30 June 2004 23:49 Go to previous messageGo to next message
What exactly do you want photo's of?
I have the flywheel and clutch off a gen3 GA70 supra at home. But the pressure plate is TRD and the clutch plate is brass button. I probably have the original organic plate somewhere but it was probably TRD as well.
The 3T-GTE flywheel does bolt up to a 1G but the clutch is smaller, by half an inch i think (9"). I used a 3T setup on my first 1G and it did the job fine.
Darren.
Bugman
Re: 1GGTE clutches Thu, 01 July 2004 00:09 Go to previous messageGo to next message
I have a feeling the standard one was only 500ish KG.
Bugman
Re: 1GGTE clutches Thu, 01 July 2004 00:49 Go to previous messageGo to next message
I got the standard clutch lying in my parents garage I guess i could take a pic of it if it will help.. looks like a clutch though Smiley =
jasonp1977
Re: 1GGTE clutches Thu, 01 July 2004 00:50 Go to previous messageGo to next message
from this page: http://www.trdsales.com/shop/product.asp?catcode=1 95
The 3rd gen 1ggte clutch plate (TRD part# 31250-SW251) is used in the:
-gx81 twin turbo
-GA70 twin turbo
-JZA80 N/A 5-speedS
-ST215 3S-FE Corona and Carina
-All GT4 Celica's
-SW20 turbo.
The specs they list for the pressure plate are:
diameter: 236mm
standard clamp: 675kgf (6615N)
TRD Spec Clamp: 870kgf (8526N) part# 31210-GA754
The pressure plate is a common part between the late GA70 and GX81's
CrAiGzEE
south of the big smoke
Re: 1GGTE clutches Thu, 01 July 2004 04:21 Go to previous messageGo to next message
does that mean this will fit??
http://forums.toymods.org.au/index.php?t=msg&t h=38417&start=0&rid=35&S=ccf96b68070a5 dcfe0a1af5ea1f4005e
ra23celica
Re: 1GGTE clutches Thu, 01 July 2004 05:14 Go to previous messageGo to next message
For what it is worth on that TRD USA parts website, the 5M, 3S-GTE, 7M-GE and 7M-GTE all list a 236mm clutch.
Bugman
Re: 1GGTE clutches Thu, 01 July 2004 05:20 Go to previous messageGo to next message
it's only a friction plate for starters and does the r154 have the same input gear as the w58?
Re: 1GGTE clutches Thu, 01 July 2004 09:13 Go to previous message
Interesting, I'll have to see how mine is. It's a 9" one as my engine is a Gen2.
I can't seem to find out anything about the Gen2 one, as everything lists the 236mm one. All I know is mine is now 40% beefier than it left the factory Razz
Previous Topic:TVIS??????
Next Topic:ae86 : diff clunking in the rain
Current Time: Sat Nov 21 16:45:18 UTC 2026
Total time taken to generate the page: 0.0047621726989746 seconds
